Originally Posted by WalterNY
I mean pulling behind a vehicle that we can drive separate from the skoolie.
This is commonly referred to as a "towed Vehicle", also referred to as a "Toad" for short. There's 3 ways to do this:
1. Place your vehicle on a full trailer,
2. Place the drive axle on a car or tow dolly,
3. Tow the vehicle on its own 4 tires (also called "Flat Towing". No, this does not mean anything about flat tires.)
Some vehicles are not recommended for flat towing *AT ALL*, and some are not recommended for car dolly towing (typically AWD vehicles). Some vehicles can be flat towed if you disconnect the driveshaft.
If you already have your "toad" then you'll need to determine which method the manufacturer recommends/approves. If not, then use your preferred towing method as a factor in deciding which "toad" you want to buy.
