Old 01-29-2020, 03:46 PM   #1
stlthe's Avatar
Chassis: Saf-T-Liner MVP EF
Engine: Cat C7
Rated Cap: 29 (Perimeter Seating)
can anyone ID these for me? air connections i think, but watfer?
Hi
I am curious as to the purpose of these two items:
thing 1 is mounted just above and left of radiator, in center grill section, its yellow button says 'push to reset'. TOP Pic
thing 2 is located behind driver side front access panel where the wiper motor is. BOTTOM 2 Pics
thanks for any ideas or even guesses!
Evan
stlthe is offline   Reply With Quote
Old 01-29-2020, 04:32 PM   #2
#1 looks to be an air filter restriction indicator. If you look at it from the side, it should look something like this.
#2 Is an adjustable air pressure regulator. You'll typically find these on the stop sign arm or the air door arms. It's used to adjust the speed/force those air items operate at. Follow the hoses connected to it and see where they go.
Old 01-29-2020, 04:57 PM   #3
stlthe's Avatar
Engine: Cat C7
thank-you, i was wondering where to control the door speed/pressure.
evan
Old 01-29-2020, 05:05 PM   #4
evan
Follow the lines to be certain what it is used for. Typically the regulator for the air doors is above the door itself where the cylinders are. And usually the regulator for the stop sign is located in the compartment below the driver's side window. So being where this specific one is located, it could be for something else.
Old 01-29-2020, 06:45 PM   #5
Chassis: IH
As for the filter minder, basically it keeps track of how much "vacuum" the intake system generates, when it reaches a certain threshold, the 'minder will "lock" to a yellow/red indication, at which point it's time for a new intake air filter. Reset this when the filter is changed. (Basically, it simply "locks" when a certain amount of "vacuum" is sensed, the yellow button releases it).
Old 01-30-2020, 06:14 PM   #6
stlthe's Avatar
Engine: Cat C7
thanks guys for clearing this up!
e
Old 01-30-2020, 07:51 PM   #7
thing 2 looks like the air valve for probably the stop sign or a pop out crossing arm if your bus has one..
Old 02-06-2020, 05:54 AM   #8
Yeah it should be an air pressure regulator.
Jamdani is offline   Reply With Quote
Old 02-15-2020, 04:15 PM   #9
Look on your air filter. There should be one there to measure if your filter is restricted.
Dirtdoctor is offline   Reply With Quote
