Old 11-30-2022, 06:10 PM   #1
Can I ID my Transmission with my VIN?
I am selling our converted 2000 International 3800 mid-size and a few have asked about the transmission. Is there an online decoder that is reliable/accurate? My VIN is: 1HVBBABN0YH261685
Any tips would be so appreciated.
Thanks so much.
theresabusinouryard is offline   Reply With Quote
Old 12-01-2022, 12:24 PM   #2
Coachwork: IC
Chassis: CE200
Engine: VT-365
Rated Cap: 29760 GVWR
Thanks so much.
https://repairlinkshop.com/Account/Login?navistar
I have used the repairlink to find information on my bus. You can also snap a pic of your transmission serial number and go to
https://allisontransmission.com/part...y-transmission
Plug in your serial number and they should be able to tell you everything you need to know.
Samarath is offline   Reply With Quote
Old 12-01-2022, 01:33 PM   #3
Dbacks2k4's Avatar
Year: 2006
Chassis: IC CE300 (PB105)
Thanks so much.
The post above from Samarath is dead-on for looking up build-sheet info using repairlinkshop.
Your bus came with a ALLISON AT5454-SPD AUTO TRANS. Doesn't mean it hasn't been changed out to something else in its past though, only way to know for sure is to crawl under and grab the serial number off the plate that's on the side of the transmission and go to the myallison website and enter the serial number there.
Cheers!
Kevin
TSLABUS Build thread:
https://www.skoolie.net/forums/f11/j...ert-38328.html
TSLABUS YouTube Channel:
https://youtube.com/@thetslabus
Dbacks2k4 is offline   Reply With Quote
allison transmission, international 3800, mid size school bus, vin decoder
