Old 12-19-2019, 01:20 AM   #21
Chassis: ThomasBuilt 30'
Rated Cap: me + 1
The floor of my bus is attached to the chassis rails with these clip/bracket things:
Attachment 39884
They're a slightly-bent piece of formed sheet metal that bolts into the bottom of the cross-member and clips the body to the top flanges of the chassis rails. Does anybody know what these are actually called and where I could find eight or so of them online?
I basically need to clip my new frame to the chassis in the same manner. I've though of a few ways to improvise something to do this, but I'd rather attach something meant for this.
I'm thinking a straight piece of 1/4 inch, same width and length as the originals, drill a hole in same spot, phosphate and paint, put some washers the same thickness as the frame metal (or slightly thinner) under the strap/clip and bolt it down. Done. You could weld a piece the same thickness as the frame under the strap, then drill the hole, if you wanted something prettier or stronger. This is just s clamp.
Old 12-19-2019, 10:26 AM   #22
Oh WOW! i was searching for an answer and found this forum topic, those are pricey! Now i need to think if it as all was worth the hassle! Thank you for coming to help though
DrakeFrst is offline   Reply With Quote
Old 12-25-2019, 04:32 AM   #23
sojourner's Avatar
Engine: DT408
If it were me, I'd use 2" channel and a spacer the thickness of the frame rail.
I am an sojourner in the earth; hide not Your Commandments from me. Psalm 119:19
Here is the patience of the saints; here are the ones keeping the commandments of YAHWEH, and the faith of Yahshua. Rev. 14:12
sojourner is offline   Reply With Quote
Old 01-20-2020, 08:37 PM   #24
Made my own
These are the same length (6") as the factory clips and the same width as my two transverse t-bars. The double bolts should serve the same role as the tab and notch in the factory clips, preventing it from twisting. The surfaces that will mate with my t-bars and the chassis rails are rounded and smoothed. The flat part of the clips is 1/4" and that would probably be strong enough on its own, but I added 3/16"x1" stiffeners along the bottom.
Old 01-20-2020, 08:48 PM   #25
The floor, technically, yes. Those clips hold the whole unibody to the frame.
You lost me on clipping the frame to the chassis?
Looks like those brackets are a bus scrap yard find.
Did he have dyslexia or something?
Old 01-21-2020, 01:47 AM   #26
I'll repeat what I posted to your build thread ....
Nice work, very nice work!
Old 01-21-2020, 09:21 AM   #27
He may have had dyslexia or something, but his real problem is that he values money over everything else. Every post of his is about what a great "deal" he got (even to the point of obvious online scams where he had to get Paypal to refund his money), or how much profit he made with his latest quick sale.
He's pretty sure he's going to be the one guy who's Nigerian Prince will someday come.
