Old 11-24-2019, 04:18 PM   #1
dzl_'s Avatar
Decent Article on School Bus Fuel Economy
How to Boost Fuel Economy (School Bus Fleet Magazine)
dzl_ is offline   Reply With Quote
Old 11-24-2019, 05:09 PM   #2
Year: 2005
Chassis: FS65
Engine: Mercedes 6.4L
http://www.seeiiairfoils.com/uploads...I-BROCHURE.pdf
not sure how much one of these would help, if it were significant, I'd think you'd see them every where.
BarnYardCamp is offline   Reply With Quote
Old 11-24-2019, 05:29 PM   #3
Those have less to do with fuel efficiency as it does keeping the back from accumulating snow and dirt sucked up in the vacuum.
Old 11-24-2019, 05:36 PM   #4
Yeah it forces air down to keep the back windows clean. I really want one just for the cool factor.
Roll Your Own Build Thread
Old 11-24-2019, 05:39 PM   #5
very interesting. thanks. I really liked the part about the various tire types (fuel efficient vs ones for lots of starting and stopping). I didn't think about there being a difference. Since we will mostly be doing "distance driving" - especially as compared to a school bus picking up kids - we will have to consider this when we replace tires.
BetterWayLiving is offline   Reply With Quote
Old 11-24-2019, 06:04 PM   #6
dzl_'s Avatar
Yeah that is the part of the article that I found most interesting as well. It went into mroe detail than i'd heard before
Old 11-24-2019, 07:12 PM   #7
Mine is currently off since it needs to be repainted (it's aluminum, BTW, so it's extremely light). The mounting for them is actually pretty simple, it's just eight 5/16 rivnuts run into the end cap (no special bracing or anything on the bus needed) and then a couple of simple brackets you bolt together.
I'm sure I won't have it back on until next year some time, if that. I could probably be talked into trading it for something useful. I called the company that makes them, and the guy I talked to said they retail for $650 to $1000 (I would not expect anywhere close to that in value, just thought it was interesting).
