Old 07-20-2020, 12:52 PM   #1
Chassis: Carpenter SB 2508
Engine: Navistar DTA360 disel inline 6 cyl, 5.9L
Driver's window - advice needed
Hi All,
I need some help with my driver's side window.
Background: the driver's window leaked like a sieve, so I removed it, cleaned it and the frame, added new butyl tape and seam sealer, and reinstalled the window with more seam sealer. It still leaked something awful. I figured the window gaskets were bad; I accidentally broke the two windows and screwed up the frame removing the window the 2nd time; it's not repairable.
I called everybody and their brother around the US and cannot find a replacement window (I have a 1992 Navistar DTA360, Carpenter SB 2508 chassis).
I figured I'd install sheet metal and an RV window, which I purchased. My concern is that the RV window is tinted and just doesn't provide as much visibility as the original window. Plus I'm concerned the tint may be a hindrance to night driving visibility.
Here's the question: Would it be possible to install a different make bus window into the sheet metal frame? If you think so, how?
Kathy K
Kaklehr is offline   Reply With Quote
Old 07-20-2020, 03:50 PM   #2
plfking's Avatar
Rated Cap: 34
When I skinned over my original door, I bolted in tube stock above and below, turned a 'standard' window sideways, removed the latches, and screwed it in. Then skinned around the perimeter.
Works as well or better than my driver's slider.
Don
The Busted Flush
Old 07-20-2020, 04:25 PM   #3
https://www.wheelerfleet.com/product...yABEgJajvD_BwE
Old 07-20-2020, 05:32 PM   #4
Looks cool. What did you use to fill the side blanks?
Kathy K
Old 07-20-2020, 06:59 PM   #5
I have already looked for a carpenter window.. carpenter has gone out of business a long time ago.. it appears an 'IC' driver window can be made to fit a high headroom carpenter bus.. a Wayne window (just as hard to find) was a drop in replacement on a carpenter as well.. school bus junkyard will be your best bet. a Thomas High headroom bus like an HDX is a possibility as it looks similar.. I sort of repaired my driver window so I havent gone on a mission to find another one.. I do know of a good one if your bus is a low headroom.. some friends are parting out a low headroom mid-90s Richmond-built carpenter..
Old 07-20-2020, 07:38 PM   #6
plfking's Avatar
Rated Cap: 34
I skinned the opening with one of the interior ceiling panels I removed.
I went this route because I, too, called everybody and their brother AND their sister trying to find a driver's slider window, with no luck.
Don
The Busted Flush
Old 07-20-2020, 08:02 PM   #7
HI Christopher,
I'm not sure what you mean by "low headroom". The window opening is 28 3/4" tall x 32" wide.
Kathy K
Old 07-20-2020, 08:09 PM   #8
Hi Cadillackid,
I'm VERY interested. Thanks!
Kathy K
Old 07-21-2020, 07:06 AM   #9
high headroom vs low headroom has different heights for the windows, yours is a high headroom window opening, same as mine.
the bus being parted out is a low headroom meaning the driver window is a different size..
Old 07-21-2020, 07:57 AM   #10
U sure about that Chris? I'm pretty sure on at least Thomas buses they only used one size driver window.
Old 07-21-2020, 08:26 AM   #11
Bluebird conventionals used one, carpenter and IC used 2, Thomas used 1 on conventional ..
The busses we are talking about here are carpenters
Old 07-21-2020, 08:29 AM   #12
10-4. Just was wondering.
Old 07-21-2020, 09:32 AM   #13
Thanks for checking Chris. Guess I'll go the - skin & RV window route.
I really appreciate all your feedback!
Cheers, Kathy
advice needed, driver's window, leaky window, rv window
