Old 06-18-2024, 03:51 AM   #1
Year: 2008
Engine: CAT 3126
Electrical Issue in 99 Thomas Freightliner Bus
Hello,
My bus won't start. I've replaced the battery, the starter and the starter relay. The ignition switch bench tests just fine. I've secured all the safety doors and made sure the bus was in neutral in case it was a hidden switch somewhere getting in the way.
When I turn the key in the ignition, I can hear something clicking underneath the hood, but can't identify it what it is. It's slightly faster than 1 click per second, clicks 5-6 times, then stops. It sounds like that clicking is coming from a cluster of solenoid relays above the engine. I can't tell whether they are in between the starter relay and the starter - it looks like they might be, but that would also be confusing to me. I have not been able to find a wiring diagram for this beast. I don't want to replace all of them, but I will if I have to.
juniorfalcone is offline   Reply With Quote
Old 06-18-2024, 06:37 AM   #2
Chassis: TC/2000
Engine: 5.9 Cummins 12-valve
Rated Cap: 1
When you say "solenoid relay" are you referring to a cube or a round item? If you have proper voltage to the item(s) then you may have a bad ground. Somewhere.
Be specific on the bus you have and put it in your registry. It will help now and later.
BamaBus is offline   Reply With Quote
Old 06-18-2024, 09:59 PM   #3
Year: 2008
Engine: CAT 3126
merge fruit
I got it. My problem was solved after I tried bypassing the a relay (looks like a starter solenoid) with a small jumper wire the same gauge as the other wires on the terminal.
Old 06-19-2024, 11:24 AM   #4
ewo1's Avatar
Originally Posted by juniorfalcone View Post
Hello,
So much information but zero mention if the motor spins when you turn the key !
How do you know that it is a wiring problem.
