Could be a Maxxforce 7 as well.
It depends on the model plate by the service door (could be a BE, CE, RE, or FE, maybe even an AE)
Using a CE for example: (I think they changed the model plates around 2012-2014) the CE200 would be a V8 (T444E, VT365, or Maxxforce 7 depending on year), while the CE300 would be an I6 (mainly a DT466E, or Maxxforce DT)
Now not all the International IC bus models had all engine options available and some only had a specific engine type. Example would be an IC FE, which was equipped with the I6 engine only and was marked as an FE300 as such.
Now being a 2009 model year, it would have the Maxxforce 7 V8 or Maxxforce DT I6 in it.
