Old 04-29-2020, 05:48 PM   #21
Engine: DT466E Navistar
Rated Cap: 28,900
Thanks man, appreciate it
Smitty
Smittybilt is offline   Reply With Quote
Old 04-29-2020, 05:57 PM   #22
Rated Cap: 28,900
Thanks to all of you.....
That took the time to read through my little episode (s) on my first ride.
More to come! Moving the bus to it's permanent parking/build spot this weekend, using it to move all the stuff I have in two storage units. Once all that malarky is done the floor work will begin!
Smitty
Old 04-29-2020, 08:30 PM   #23
Made the move out of the storage units with the seats in???
Old 04-29-2020, 09:16 PM   #24
Rated Cap: 28,900
That'll be this weekend, luckily enough the seats and ceiling have already been removed
Old 04-29-2020, 11:00 PM   #25
So much easier with the seats removed. Good going.
Old 04-30-2020, 07:09 AM   #26
Chassis: Saf-T-Liner MVP
Engine: CAT 3116 (TA185) / AT545
Originally Posted by Smittybilt View Post
. I got the bus started again and it would idle fine, but as soon as you try to go anywhere it would stall. It started up again, revving it up in neutral it was fine. And it would idle in gear and move the bus, but as soon as you put a load on she would shut down.
This sound like a problem I had, buy two new fuel filters, replace one, run some kerosene thru the tank and have the other ready for when it happens again. If you have trouble getting the old one off, try using a leather belt as a wrench.
BusWanderer83 is offline   Reply With Quote
Old 04-30-2020, 08:02 AM   #27
Rated Cap: 28,900
kerosene....
So this is one of the things I’m still trying to figure a good solution for. Do I need to drain the tank to get rid of the old jelled fuel? Does the kerosene help with the jelled fuel? Any other things I could remedy the jelled fuel with?
Thanks for the suggestions, Smitty
Old 04-30-2020, 03:58 PM   #28
I didn't see the part about the jelled fuel. I'm not sure what you mean by that but... I was told that kerosene is a much more refined diesel so it can fight thru the gunk and get to the engine. I'd certainly try that or seafoam plus the new filter before I went thru the headache of getting the fuel out...maybe if you have a siphon long enough to get down to your tank, see how much will come out and what condition it's actually in? Less junk fuel to dilute the good stuff also. Hope it works out but these kinds of things make great stories later down the road ;)
Old 04-30-2020, 04:50 PM   #29
Look at the bottom of the tank. There should be a drain plug. Put a 5 gallon bucket under the plug, remove the plug, and let a few gallons drain out. Pour some into a clear container and let it settle. This will give you a look at the worst of what is in your tank. Take pictures and post them.
Old 04-30-2020, 06:02 PM   #30
Phatman's Avatar
Great story
Smitty, that is one of the best stories I've read in a long time. I think you're headed in the right direction.
Old 05-02-2020, 04:10 PM   #31
TheHubbardBus's Avatar
Coachwork: IC / Amtran
Chassis: CE300
Engine: International T444e
Rated Cap: 23
Excellent story, Smitty! I was on the edge of my seat! And glad, since it's more than just a story, that it had a happy ending! That brings back memories from our trip home from auction, which was a similarly stress-inducting affair. But that just makes it more of a relief - and a better tale to tell - when you manage to get 'er home.
Go away. 'Baitin.
Our Build: Mr. Beefy
Old 05-02-2020, 09:08 PM   #32
Rated Cap: 28,900
Draining the fuel in a 5 gallon pail....
That sounds like a good plan right there. I'm going to purchase a large oil drain pan, maybe that will work if I need to drain it. It'll be a week or two before I have a chance to mess with the fuel issue, but when I do I'll definitely snap a couple shots.
Thanks, Smitty
Old 05-02-2020, 09:10 PM   #33
Rated Cap: 28,900
I'm glad you enjoyed it TheHubbardBus
Old 05-03-2020, 07:32 PM   #34
Rated Cap: 28,900
Much appreciated Phatman
Old 05-08-2020, 04:26 PM   #35
I just saw this. Glad you got home. Next time you're DOA in Keene gimme a call; that's where I live.
I do not suffer from mental illness. I enjoy every damn minute of it!
