Old 05-28-2021, 12:54 PM   #1
chromaglow's Avatar
Chassis: All American RE Flat Nose
Engine: Cummins 8.3 260 Allison MD3060
Rated Cap: Just 1 right now
Smile Floor Holes
I'm about to finish my floor and need to seal the holes from the plywood that used to be there. I'm going to use Henry 212 unless I hear a strong reason to use something else. Should I seal them before I paint with Rustoleum or after? Not sure if the 212 is paintable or if that is advisable??
chromaglow is offline   Reply With Quote
Old 05-28-2021, 01:01 PM   #2
DAVEHOLMAN's Avatar
Coachwork: Thomas Saf-T-Liner
Chassis: HDX with lift
Engine: Mercedes MBE 920
Rated Cap: 22
I painted first, then used aluminum tape to cover the holes.
DAVEHOLMAN is offline   Reply With Quote
Old 05-28-2021, 01:48 PM   #3
Sikaflex and pennies
