Old 03-22-2022, 02:06 PM   #1
Fuel Lift Pump needed
Hi all,
Can anyone help me source a second hand fuel lift pump? It's on critical back order for a new one from International, so looking at other options..
Listed on the part is "F/F assembly, non-heated. 1873938C95"
thank you!!
Zenproject is offline   Reply With Quote
Old 03-22-2022, 02:36 PM   #2
Whats the year and engine ?
Vapor Ghost is offline   Reply With Quote
Old 03-22-2022, 03:56 PM   #3
It's 2009 VIN 4DRBUAAN49B098251
Does that give you the info you were looking for?
Old 03-22-2022, 09:30 PM   #4
Engine: 7.3
Rated Cap: 5 Window
https://www.ebay.com/itm/26476747601...id=19037899727 The numbers don't match but the year and engine does. You have a picture of your old one?
Spaznaut is offline   Reply With Quote
Old 03-23-2022, 02:25 AM   #5
Here are the images of the part
Old 03-23-2022, 08:53 AM   #6
Engine: DT 466 Mech. Spicer 5 speed
Rated Cap: 34
To me-- that looks like a fuel filter housing, with a manual primer pump.
Maybe a manual water drain valve, and water in fuel sensor.
What part of that has failed? Is it leaking air or fuel? Primer pump doesn't pump or leaks fuel?
If the primer pump is leaking-- maybe you could block it off temporarily?
PorchDog is offline   Reply With Quote
Old 03-23-2022, 09:31 AM   #7
Yes you are right. I believe I was given the wrong description. The part in the photo is the part that needs replacing. It's allowing air to come in via one of the valves and causing loss of power.
We have one on critical back order with international. I also want to try and find one as have concerns over how long that order will take. So any help on where I may find that part would be really appreciated
thank you!!
Old 03-23-2022, 10:18 AM   #8
Chassis: International 1753
Engine: 6.9 International
This right here.
The lift pump is on the hpop, which is separate to what you have pictured. As you've found, new fuel filter housings are backordered. There are individual repair components if something on yours is broken.
BTW, I believe 1873938C95 has been superseded to 1873938C98. Still not available but you might have better luck with that number.
Old 03-23-2022, 10:21 AM   #9
might check around with some truck / bus junkyards, being an 09 its coming fro ma Maxxforce 7 Or Maxxforce DT.. there were a lot of these that had internal engine failure where the fuel bowl / filter assembly would still be good
Old 03-23-2022, 01:27 PM   #10
If anyone knows of any good yards to contact that would be super helpful. I'm based in the UK and wondering where to start! thank you for helping me to understand I had been calling this part the wrong thing.
thank you everyone
Old 03-23-2022, 03:32 PM   #11
thank you everyone
This is NOS on ebay.
https://www.ebay.com/itm/35371032175...QAAOSwrqRhXd21
And it shows international shipping as an option.
Old 03-23-2022, 03:56 PM   #12
Well this is amazing - looks like I have my part.
What a helpful group this is. sending a lot of gratitude from London!
Check out what our bus gets up to when it's on the road here - www.t-z-p.com
Old 03-23-2022, 10:46 PM   #13
Awesome great work guys ! If we all work together in a civilized manner I don't think there's much we can't work out..
Old 03-27-2022, 05:56 PM   #14
Coachwork: Our hot little grubbies...
Rated Cap: Three RedHeelers
Try these folks:
https://m.facebook.com/andersonbrotherseugene/
Eugene, Oregon.
Anderson Brothers Heavy-truck wrecking on Highway 99 at Beltloop.
The counter-staff will probably take your information, pass it to the owner, a fellow named 'Mark'.
Mark keeps seventeen-dozen plates in the air simultaneously, so another call or three might help.
LargeMargeInBaja is offline   Reply With Quote
