02-22-2020, 09:49 PM
#961
Sweet! What's next?
02-22-2020, 10:46 PM
#962
Originally Posted by Native
Sweet! What's next?
Rear end fluid change on the bus.
O2 sensor on the truck.
Shifter rebuild on the miata. Its not shifting bad or anything, but I wana do it anyhow.
02-23-2020, 12:23 AM
#963
Busy, busy, busy!
02-23-2020, 08:35 AM
#964
Busy, busy, busy!
Yep.
I also want to change the oil in the front hubs in the bus. Its gross.
02-25-2020, 12:16 PM
#965
I finally put the O2 sensor on the truck. WOW! What a difference. Feels like 50% more power!
I'm thinking I'll be getting better mpg's now.
THe old O2 sensor was just broken off and left threaded into the manifold, so my manifold has been leaking exhaust gases this while time too.
Now to figure out where the oil leaks are coming from and do the sparkplugs.
02-25-2020, 05:59 PM
#966
Changed spark plugs. Took about an hour to do all 8. Used anti-seize on them. One of the easier spark plug changes I've done. Will get new cap, wires, and rotor when there's a sale or some sort of discount code.
Got an ac delco oil filter, new rad cap, and 8 ac delco plugs for $30 after a 25% discount at advance auto. Also had discover cash back points so I didn't actually pay anything out of pocket!
02-27-2020, 12:10 PM
#967
Made my own one man bleeder. It sure makes it a lot easier.
Put a tube into an empty bottle with just enough brake fluid to cover the end of the tube in the bottle. Put the tube on the bleeder valve and crack it. Pump till the air is gone. Easy!
Got the lines all re-tightened and re-bled the system FIRM pedal now.
Next up for the brake on this truck will be to eliminate the rear ride height proportioning valve and replace the rubber brake hoses. Thinking of going all out with fancy stainless braided lines.
Gonna smoke one then go get a new hose clamp for the vacuum tube on the booster. Been using a zip tie.
02-27-2020, 06:29 PM
#968
Sooooo- spent the last hour trying to get the last brake line to thread into the proportioning valve.
NEVER again will I do this job, at least this way.
IDK what to do. I simply cannot get it to thread no matter what I try.
Edit- GOT IT!!!
I guess cooling down in the AC and another doob got me re-energized. Its hot out today. Sunny and in the 80's.
Anyone in the area wana help me bleed these brakes? I got a case of beer for ya.
The truck is gonna get more love from here on out. Its been a good one, and got us through the last year as our main means of getting around.
Now that we have a fully functioning bus and a sweet running miata the truck can finally get some much needed r&r.
Speed Bleeders, one man bleeding. Just put them on the Miata.
02-27-2020, 08:01 PM
#969
As a bonafied shade tree mechanic ... I approve this message. (It is, after all, how I bleed my brakes.)
02-27-2020, 10:02 PM
#970
Yep. Makes the other methods seem pretty futile.
02-27-2020, 10:55 PM
#971
Ooooohhhhh I like using a bottle with a cap and a hole. Sure beats the ol' Mason jar.
02-28-2020, 06:33 AM
#972
Engine: TE 444
Rated Cap: 12
Just buy another 1200 dollar junk truck with 360K miles like I just did
02-28-2020, 06:37 AM
#973
Roxy thinks you and I are very similar, Kubla. Goin to look at an 85 blazer today. Runs and drives and they're only asking $1500.
02-28-2020, 09:40 AM
#974
Engine: TE 444
Rated Cap: 12
Real blazer or s10 blazer, if s10 with v6, run away
02-28-2020, 10:03 AM
#975
85 Blazer will be a real Blazer.
02-28-2020, 01:31 PM
#976
Well-obviously. I'm talking about real Blazer!
It sold yesterday, it seems. Figures- that price was crazy low. Shucks.
03-02-2020, 12:50 PM
#977
Got a new throttle cable on the truck this morning. Pretty simple job.
Discovered a new coolant leak at the thermostat so I got a new stat and gasket. And a couple hose clamps.
If I get this done quickly I'm doing an oil change and I grabbed a pack of oil pan bolts since mine is missing two of them.
03-02-2020, 01:25 PM
#978
Dude you are on a serious maintenance kick.. When you run out of things to do on your cars come on over I've got more!
03-02-2020, 03:15 PM
#979
I was gonna ask you if you're interested in helping me do a couple bigger jobs.
Trying to make our stuff last as long as possible. New vehicles are junk and I'm holding on to what we have!
oddly- my bus is missing at least one oil pan bolt as well.
03-02-2020, 04:08 PM
#980
I've got an intake manifold and valve cover gasket set to do this week, parts should be here tomorrow...
