Old 10-31-2018, 10:57 AM   #1
Hello! Interested on your opinion of the t444e
We're about to buy a 30ft bus with a 175 hp t444e engine. Is this engine strong enough to last year's when the added weight of the conversion is added on? Is this a good long-term engine?
jamesd20 is offline   Reply With Quote
Old 10-31-2018, 11:00 AM   #2
What year, trans, bus make?
Old 10-31-2018, 11:18 AM   #3
It's a 1994 thomasbuilt but I'm not sure about the transmission
Old 10-31-2018, 11:25 AM   #4
Unless its a manual transmission then its going to have a 545.
A 175hp 444 and a 545 is a miserable setup on the highway.
Roll Your Own Build Thread
Old 10-31-2018, 11:36 AM   #5
Too slow or too much gas? I don't mind if it's slow
Old 10-31-2018, 11:39 AM   #6
Strains too hard to maintain highways speeds and the heat from the 545 pushes the cooling system pretty hard. The temps shoot up and you're forced to go really slow. Its just not what I'd buy for driving on the interstates and highways.
Old 10-31-2018, 12:16 PM   #7
If I maintained 55mph would I be ok?
Old 10-31-2018, 12:32 PM   #8
Brokedown successfully toured the US in a T444e/AT545 equipped Vista.
It can be done. I surely do not have the patience.
If you plan on significant travel, i would recommend looking at some buses with higher horsepower and a lockup transmission.
Old 10-31-2018, 12:59 PM   #9
I did a lot of miles on my T-444E / AT545.. both brokedown and i have short busses..
my AT545 trans gave up about 16 months ago so I upgraded to a better trans.. (Lockup + overdrive) and most recently I repgrogrammed my computer for the max 210 HP.. in a short bus the 444E is a fine engine.. in a long bus its going to work hard.. its not always a matter of staying at 55.. if you are running a 444E hard they often make heat and run hot in summers esp if you are in the south where its 95+ degrees..
Old 10-31-2018, 02:03 PM   #10
Johnny Mullet's Avatar
Engine: T444E 7.3L
I have the same bus and love it. It's a turd on the hills, but super reliable.
Old 10-31-2018, 02:23 PM   #11
Dog Rescuer's Avatar
Engine: 7.3L 210HP Turbo Diesel T444E
Rated Cap: 28 + 3 wheel chairs.
My t444e engine was straining a bit when the temperatures were in the 90s - other than that it has been tooting like a champ. I still keep it at about 55mph on the highways. The 210HP is nice.
The only over heating was driving through Wyoming up a 10% grade for 13 miles - I had to pull over and cool down 4 times. I averaged 20-25mph up the hill. Coming down was a lot of braking - I had to stop twice to let the brakes cool down.
- Roger (Dog.Rescuer)
Dog Rescuer is offline   Reply With Quote
Old 10-31-2018, 02:27 PM   #12
Attachment 26985
Attachment 26986
you are lucky to have that 210HP.. (I finally figured out how to re-program mine for the 210.. and woah! in a little bus that thing flies now) last time I read the computer on yours everything was tip-top shape!! your bus has a lot of life left in it... onward to california you go!!! take the southern routes!! weather changes QUICKLY in the rockies this time of year!!
Old 10-31-2018, 02:29 PM   #13
Attachment 26985
Attachment 26986
P.S. I forgot to mention i did that wyoming grade this summer.. in a GASOLINE 40 year old bus.. with an AT540.. so alas any bus can really do anything as long as you do as roger did and take it easy!
Old 10-31-2018, 02:40 PM   #14
Yours has an allison 2000 transmission though, right?
If so they're night and day in terms of how they drive and how long they live.
Old 10-31-2018, 02:41 PM   #15
Attachment 26985
Attachment 26986
Don't you also have a 2000 and not a 545?
Old 10-31-2018, 02:47 PM   #16
roger has a 5 speed allison 2000 and 210 HP.. I didnt think that extra 20 HP made that jmuch difference till i altered the program in mine..
Old 10-31-2018, 03:26 PM   #17
BIG difference, imo.
Old 10-31-2018, 04:12 PM   #18
The 210hp allows you to make more use of your overdrive gear.. Roger”s numbers show if too.. he has run all over the mountains with a full conversion and towing his Subaru , yet still netting around 10 MPG, with that kind of load in a 175 or 190 he would’ve been out of OD and wasting fuel a lot more.
The 444e fuels conservatively based on throttle but logs easily , the factory Allison program is designed to run highest gear it can on light throttle but if you crowd the engine at all it’s going to downshift.
The result is that the higher HP models tend to stay in OD much more than the lower ones..with much better MPG as a result.
My reprogram to 210 is recent but I can already note that I’m in 6th gear more than previous. In 6th gear at 65 it practically idles along at 1600 rpm.
Christopher
Old 10-31-2018, 04:36 PM   #19
Johnny, how does it handle highways?
Any tips for how to get the most out of this bus?
Old 10-31-2018, 04:51 PM   #20
Christopher
When did you learn how to get more hp? I want some more hp!
