Welcome to the site Teku.
Unfortunately, if you need to solicit outside sources of funding to build a skoolie of your dreams, it might take you awhile.
Most folks have planned out and saved up enough to purchase a bus. Then comes the expensive part; building it out.
It can be done on the cheap, using recycled/used furniture and materials. It really depends how "fancy" you want it to be.
My suggestion to you is spend a few days on here reading up on how folks do a conversion. If you keep an open mind, and work hard for the end result, you'll be rewarded in the end.
I'm just a bit leery on your M/O on how to fund such a project?
Good luck, and post pics if you wind up in a bus...
