How to reduce noise of window rattling while driving?
Hey Everyone,
My windows rattle quite a bit while I am driving the bus. I have an oversized window in the back of the bus that is the worse. I guess it is 18" to 24" wide? I believe the actual pane of glass is rattling in the metal frame of the window. When I put pressure on the window with my hand, the rattle goes away. This has convinced me I need to find a way to reduce the noise between the glass and the metal frame holding the glass.
Any ideas on how to reduce window rattle between the pane of glass and the metal window frame? Shims? Rubber? Silicone? There is little space to shim.
My bus is a 2009 - 16 seater GMC / Thomas bus. The windows are a style that has tabs holding the entire window piece in place. I attached the best picture I have on me.
