FWIW, I did a full LED conversion with additional markers along the side:
https://www.skoolie.net/forums/f11/k...tml#post330205
Originally Posted by jsutara
When I go to turn them on, they turn on for a moment and then off. This happen 2 or 3 times before they stop doing that.
Could you provide video of this?
Further, oddly, the fronts are bright but as you go down the bus, they get more dim as you walk further down the bus.
Sounds like a possible voltage drop. Have you measured voltage on a bright light near the front and a dimmer light near the rear?
This is going to be a process to troubleshoot as we're not there with you to help, we can only make guesses as to the next thing to look at. So the more detailed and accurate information you can provide us, the closer we can get to an educated guess.
A few questions:
- How exactly did you wire your marker lights?
- Do you have the means to measure current on a DC wire?
- Do you have a 12V power source separate from the bus to test lights with?
