Old 03-30-2024, 11:30 AM   #41
Outside of my cell phone and storage I have no expenses so I will pay for all necessary precautions to be out in place for my pets to be safe and for the bus to cool.
Where would you suggest I can buy the mini split or rv ac
may2024 is offline   Reply With Quote
Old 03-31-2024, 02:39 AM   #42
DeMac's Avatar
Chassis: RE-300 42ft
Engine: 466ci
Rated Cap: 90
🌭Steaming Hot Dogs in Miami
Sure, to heck with physics! You will conquer where others fail. The professional K-9 handlers, with all our tax dollars at their disposal, are no match for your crystal ball & wit. 🤷You already know.
Indiana
nypost.com/2023/07/29/8-police-dogs-in-transport-die-after-trucks-ac-breaks-down-in-traffic
Houston
cbsnews.com/6-14-2023/k9-dog-dies-hot-patrol-car-second-time-in-a-week
Utah
sltrib.com/2023/07/14/k-9-loki-found-dead-inside-utah-prison-vehicle
New York
gothamist.com/10-26-23/rikers-island-k9-dog-dies-in-tragic-incident-second-doc-dog-death-in-3-years
Georgia
wsbtv.com/6-6-2023/cobb-county/4-year-old-k9-dog-dies-patrol-car-after-air-conditioner-malfunctions-cobb-police-investigating
North Carolina
wcnc.com/6-6-2023/rowan-county-k9-dies-in-hot-car
Washington DC
wjla.com/amp/news/local/k9-explosives-detection-dog-dies-inside-marked-dc-police-car
New Jersey
6abc.com/amp/gloucester-county-nj-k9-death-fire-marshals-hot-vehicle
Delaware
firststateupdate.com/k9-officer-dies-inside-department-of-correction-vehicle-in-smyrna
Old 03-31-2024, 07:57 AM   #43
Indiana
Houston
Utah
New York
Georgia
North Carolina
Washington DC
New Jersey
Delaware
this chart is on it!.. aligns with my experiments in real world on a stock bus in the sunshine ..
now an insulated bus will warm uo slower and of course covering the windows helps too, quite a bit, but in real hot weather it gets warm quickly if the A/C is off..
ive been in busses that have solar on top and are spray foamed.. so they have defacto shade over a good part of the roof and the spray foam is an obvious Mega improvement over the crappy factory insulation of esp older busses.. they stay cool with a single A/C running until it gets real hot out then a second unit runs intermittently and thigns are nice inside.. shut both units off and it starts to warm up pretty quickly.. with a fully foamed floor you'll have the best bet, otherwise the floors become a huge source of incoming heat rather quickly if its in the 80s or above outside...
in a regular house things are different.. i think about my own experience with my kitty for 15 years.. and yes the house lost power multiple times during summer time...
a typical florida home is built on a slab, slab floors will retain cool temperatures for a long time should the power fail.. a pet can easily lay on the floor and maintain body temperature.. most people have water readily available for them at all times and so they can stay cool and hydrated for hours at a time in a house wit ha power failure..
in my own house it has a basement.. so kitty could get on the kitty basket-bed I had for him in the basement (modern house clean / dry basement).. and he would stay very cool..
in winter power outages, the basement furnace set to 60 degrees on a battery backup (gas unit only pulled 700 watts when running).. would keep him more than warm enough to survive, esp in his kitty bed.. in fact typically the main house level also stayed near 60 as well..
to the OP: im not sure what kind of build out you are planning, but it needs to be pretty stout or you need to be within a few minutes of home should something happen..
you havent answered me on whether you are self-powered or have power and how many watts at your parking space.. in a stock bus during the day in florida, your A/C is going to really rack up the KwH.. even a minisplit will pull 1000-1200 watts (12,000 BTU is the biggest 110 volt unit ive seen)..
we need more details on your build to help better..
before you order a mini split you need to plan your build.. go look at them online.. Pioneer is a favorite of many here and has proven to be pretty reliable.. look at them and how you will hang the condenser unit, and where.. I cant help you there because im not underneath your bus, im not sure what your buildout looks like..
you can search the forums for mini split installs and see how others have installed / mounted and set theirs up for ideas.. my bus builds are different than many because the emphasis is on road travel for me vs being stationary..
you need to plan this move a little more.. you have a great start with a place to park and live while you build, thats a Huge advantage over many.. but plan your build, even if it means renting a room or a month to month apartment for a couple months to get rockin N rollin..
Old 03-31-2024, 08:44 PM   #44
Coachwork: Busless for now
I would never leave my mutt in a bus unless I was absolutely sure the Climate control was surefire. She's not the brightest candle in the chandelier, but I would be lost without her, especially if it were my fault. She jumped out the truck window today while I was loading the boat on the trailer and I still blame myself for the near disaster.
MAKE ABSOLUTELY CERTAIN THAT IT IS GONNA WORK!!!!
Kentucky Dreaming is offline   Reply With Quote
Old 03-31-2024, 09:36 PM   #45
Ok with the research I've done I've decided to buy two mini splits one for the front another for the back. Here a layout that I think will work best for me https://www.dropbox.com/scl/fi/q0g8y...rlx5ls8od&dl=0 Under the bus https://www.dropbox.com/scl/fi/twlze...wdh9cvxyj&dl=0 Under the bus https://www.dropbox.com/scl/fi/nuxnq...tnssvdkzc&dl=0 The bus is currently parked in a parking lot with no connections. I will have solar I have currently a diesel 15,000 W generator and the entire bus is wired for electricity. The generator is wired to the bus. I have to buy two new batteries any suggestions for the batteries for a 1993 Blue Bird International 3800?
Old 04-01-2024, 02:57 PM   #46
the bus batteries are generally group 31's. I like good batteries.. i have had good luck with Batteries-Plus AGM batteries.. there are cheap batteries available at places like rural king, interstate batteries are typically pretty high quality..
the bus batteries you install should generally be just your starter batteries and not used for solar storage or running your A/C units, etc..
use a separate bank of either lithium or deep cycle AGM batteries for your "house" equipment..
Old 04-01-2024, 09:19 PM   #47
Totally agree. My boat came with 2 Interstate batteries. (one group 24 & one group 27 on a small aluminum fishing boat.) I keep an onboard charger/maintainer plugged in year round. It gets pretty cold in winter here. I finally replaced both batteries after 9 years just as a precaution. They had never failed to ignite in all that time.
The point is this: Get good quality batteries and keep them charged, especially in cold weather. I speak only of lead-acid batteries. Other folks here are way smarter than me when it comes to other chemistries.
Old 10-04-2024, 10:31 PM   #48
I'm in Fort lauderdale
currently: oct 2024-> I'm in Fort Lauderdale.
G,Koda is offline   Reply With Quote
