I'm with Ross on the price. $12k seems like a good price for that size bus, all of the work that has been done, and those arm rests!
TLDR The price seems OK - but I would want more info and more pictures first. Can you see the bus in-person?
Things to consider:
If you're adding solar / electric, you'll have to figure out where / how to mount your lights, wires, and battery bank + charge compononents. And the added cost of electricity: our electric setup (batteries, solar panels, charge components, wires, etc) cost us $5k + easy.
I couldn't tell if they have electricity in the bus as-is, or if they're just hooking up to shore power / generator. Or maybe they have a propane fridge?
Second, adding water storage tanks could be a headache in a pre-built bus? Our fresh tank is under our bed, I cant imagine having to mount that thing in underneath the pre-built bed. You might have to hang your tanks from the undercarraige, which is possible, but will require different engeneering / plumbing than if you had a clean slate.
Again, hard to tell from the description - it looks like they are using water; bath and sink, but they mention you need to add holding tanks. Maybe they just took their old tanks out for their new bus?
