Old 01-15-2021, 08:17 PM   #1
Tickled Puppy's Avatar
Question Need Floor Plan, Measurements for Thomas HDX
I am buying a 2008 Thomas HDX with a midship wheelchair lift. The bus is 31 feet overall. I'd like to do some preparatory planning, but I need dimensions of the interior, especially from rear to the WC door, and from the WC door to the front. Does anyone here have that information? Thanks!
Old Goat Looking For A Few Good Sheep
Tickled Puppy is offline   Reply With Quote
Old 01-15-2021, 08:24 PM   #2
Chassis: G30~Chevy cutaway
Engine: 5.7/350 Chevy Vortec
Welcome to the site, almost neighbor!
Not any help on the info you are looking for, unfortunately.
Did you buy the bus sight unseen? I ask, as the inside dimensions would be high up on the list of things to check and document on a bus purchase.
For obvious reasons, I hope you bought your bus outside of the Rust Belt!
Good luck on your project, and post pics when you get it...
Old 01-15-2021, 08:24 PM   #3
Year: 1974
Chassis: "Atomic"
Engine: DD 8V71
Unfortunately, even within the same model line, there are different wheelchair lift/door placements. We recently looked at several that were identical, except that some had the lift about 24 inches in front of the right rear wheel well and others had the lift farther forward. And of course, some have the lift behind the wheel well...but that's not what you're buying, right? Do you have photos of your bus for reference? BTW, make sure you measure the wheel well placements too and factor those into your plans. They become important (read, intrusive) in your layout plans.
Old 01-15-2021, 10:00 PM   #4
DeMac's Avatar
Chassis: RE-300 42ft
Engine: 466ci
Rated Cap: 90
I measured and took pictures of 30+ buses before I actually won a bid.
Have you been inside of the bus you bought?
Maybe I've been in yours, or one like it.
How many windows on either side of the lift?
