Old 06-03-2021, 04:46 PM   #21
Originally Posted by deimoi View Post
This is the state of my steering column. Any suggestions how to fix this?
[ATTACH]Attachment 58059[/ATTACH]
You should be able to find a replacement part for that online?
Old 06-03-2021, 05:07 PM   #22
Coachwork: GMC Vandura G3500
Engine: 5.7L V8 Gasoline Engine
Thank! Will keep this in mind.
deimoi is offline   Reply With Quote
Old 06-04-2021, 03:05 PM   #23
Steering Wheel Puller
So, I made a simple puller from a piece of wood and 3 bolts. Just turned the center bolt slowly and the wheel was off in about 30 seconds.
Old 06-04-2021, 03:13 PM   #24
Chassis: G30~Chevy cutaway
Engine: 5.7/350 Chevy Vortec
Here's a start if you can't find another good used column:
https://www.ebay.com/itm/14367589953...Cclp%3A2334524
Old 06-04-2021, 03:30 PM   #25
Clever! Nice job.
Old 06-04-2021, 04:27 PM   #26
That link does not seem to fit my Vandura. However, PartsGeek.com seem to have the housing repair kit, the turn signal switch, and the turn signal lever. How about the transmission shift on the right side? Is there a kit for that?
Old 06-05-2021, 03:01 PM   #27
Another improvised jig
Another improvised jig to press down on the plate and able to remove the retaining spring.
Old 06-09-2021, 05:21 PM   #28
I have been working to take out the broken parts prior to ordering new parts and putting the whole thing together again. According to the video I have been following, the ignition switch should just pull out and the plastic housing should also just pull out. I can't get the ignition out and I guess that is holding the housing.
What else do I need to do to get those things out?
Thanks!
Old 06-10-2021, 06:07 PM   #29
It was not quick nor easy but I got the ignition cylinder out. I had to push up with a screwdriver on a protrusion that is part of a loose ring. Anyway, I'm glad this part is done.
Old 06-18-2021, 12:32 PM   #30
Tilt Steering
My bus does not have tilt steering. I'm sourcing parts to rebuild my steering wheel and other missing/broken parts. I see this item on Speedwaymotors.com and it has the shift lever, the turn signal stalk, 4-way flasher, and the tilt lever. I'm thinking that I should be able to use this package and just skip the tilt lever. Is this correct? Thanks!
Name:	Screenshot from 2021-06-18 10-26-45.png
broken turn signal, electrical, new build, no lights
