Old 03-13-2021, 08:22 PM   #1
New tires feel off. Thoughts?
Hi. We just put new tires on our 98 International Skokie bus. I know new tires usually feel a bit different as balance beads need to disperse and tread depth affects things. However, we are about 400 miles in and keep getting a strange fish tail when going approx 60 on highway. Back right side keeps pulling right every once and while. Thoughts?
brandtreed is offline   Reply With Quote
Old 03-13-2021, 08:48 PM   #2
Year: 2013
Chassis: IC RE
Engine: HT570 / 3500SP
Rated Cap: 4
1. Did you check the pressure?
2. Beads are not the best way to balance a wheel. Centra-matics are way better.
ABBus is offline   Reply With Quote
Old 03-13-2021, 09:09 PM   #3
Chassis: IH
I've had the same feeling with all new tires on tractor-trailers. My experience was that the tires stopped this after a few thousand miles (a couple weeks to a month, given the mileage we traveled.)
Yes, the pressure was full on all of them and the alignment was good too.
Old 03-13-2021, 10:01 PM   #4
I second this motion.
New tires will "feel" new for a while, especially if the brand and type was changed from what was taken off.
Deezl Smoke is offline   Reply With Quote
Old 03-13-2021, 10:15 PM   #5
if you went up in size / width it takes a little getting used to.. if you went with an aggressive drive tire they have a pretty wide footprint on the ground usually and can be a little tougher to drive.. esp in an empty bus...
running the pressure up at the higher end of the range seems to help.
Old 03-14-2021, 01:11 PM   #6
Thanks for the thoughts and tire tips. We’ll see how the tires perform on this trip. They feel a bit better today.
