Old 01-26-2018, 05:52 PM   #1
Dead pirate's Avatar
Coachwork: myself
Chassis: amtran
Engine: international dt466e allison md 3060
Rated Cap: 13 ton or so says the tit
Oil change dt466e
The oil doesn't seem to be all coming out. Is there something I'm missing?
Sent from my LG-LS777 using Tapatalk
Dead pirate is offline   Reply With Quote
Old 01-26-2018, 07:56 PM   #2
IDK, how much came out?
Should be around 6 gallons +/-
Did you take off the oil cap and the filter? My filter looks like it holds the better part of a gallon.
Old 01-26-2018, 07:58 PM   #3
Coachwork: myself
Chassis: amtran
Around 3 gallons. I found a leak at the oil pan. I'm thinking it was real low. Number 2 lower end bearing is bad. Now i got that to figure out.
Old 01-26-2018, 08:03 PM   #4
Hate to hear that!
Old 01-26-2018, 08:05 PM   #5
Coachwork: myself
Chassis: amtran
Hate to hear that!
Yeah. It could be worse. I can handle a bearing as long as i can find one at a decent price. Nothing else seems to be damaged.
Old 01-26-2018, 08:07 PM   #6
Gonna do em all or just the one??
Old 01-26-2018, 08:13 PM   #7
Coachwork: myself
Chassis: amtran
Probably do them all. $6.00 a piece
Old 01-26-2018, 08:16 PM   #8
DO EM ALL!!! And take pics!
Old 01-26-2018, 08:18 PM   #9
Coachwork: myself
Chassis: amtran
I will
Old 01-27-2018, 02:55 PM   #10
Coachwork: myself
Chassis: amtran
So, after cleaning with brake cleaner and assessing in the morning light, the pick up tube was puahed up. It knocked the magnet loose and it stuck where it was hitting the piston bolts that hold the mason bearing on. So the shavings were just the magnet getting mangled. They knocked loose one of the bolts that hold the mason bearing in. After torquing back to specs it didn't move anymore. I inspected the bearing and it didn't have even a scratch. So, its back together and writing for the gallery to set up. Ill pour oil in and we will see what happens.
Old 01-27-2018, 02:59 PM   #11
Coachwork: myself
Chassis: amtran
I bottomed out the oil pan and dented the uptake tube. That's how all the trouble began. And i lost 6 gallons of oil. I got so lucky. I even examined the oil pan after our happened. It didn't leak. Delayed reaction.
