01-15-2022, 09:19 PM
Please help, need opinions! About to travel 7+ hours for a potential purchase.RUST?
01-15-2022, 09:36 PM
Year: 2005
Chassis: FS65
Engine: Mercedes 6.4L
Rated Cap: just the 2 of us
I kind of look at rust the same way you would look at an ice berg....the part you can see won't hurt you.....
Maybe if the price was really good???
01-15-2022, 10:05 PM
Engine: DT466 / MD3060
Get photos first!!!!
Don't take "example photos" make them go out there with their phone and take actual photos. If you don't get this bus, your bus is still out there - it took us about 4 months to find ours and it is a unicorn well worth the wait.
Those example photos dont look great either, I would worry about that air tank first (assuming that rusty tank is the air tank), muffler second, and chasis frame third. . . the frame might not be as bad because the metal is thicker = more for the rust to have to eat through. But the compressor and muffler look close to holes to me. . .
I'm no exper though, for sure someone else here knows more than me
01-16-2022, 12:03 AM
Chassis: TC2000 28ft
Also, that is a TC2000 with a Cummins 5.9 confirmed in the picture. The only engine available in that bus. It's a great engine, just know there's nothing rare about that bus
01-16-2022, 06:48 AM
Year: 1974
Chassis: "Atomic"
Engine: DD 8V71
If the seller is wrong about the engine...whether misinformed or intentionally...then I would be pretty suspicious about the accuracy of his/her "just surface rust" claim. And, while an 8.3 would certainly be matched up to a 2000 or 3000 series Allison, the 5.9 might be paired with an AT545...which would also be less desirable, and less valuable, than the drivetrain the seller described.
01-16-2022, 07:00 AM
The rust on the underside in those pics is not as bad as it gets ( this is as bad as it gets), but:
* That muffler is new-ish but it's connected to much rustier exhaust piping which is very expensive to replace (a lot more than the muffler itself).
* The rust you really need to be concerned about is rust in the body, the part that is resting on top of the chassis rails in that picture (the body includes the roof, walls and floor). Although the underside of a bus in salt-using areas can look very bad, buses generally rust from the inside out; water gets in through gaps in the roof panels, failed light gaskets, and leaking windows, permanently soaks the plywood and then rusts through the floor. You're not really going to know had badly the floor is damaged until you rip up the plywood.
The general advice here would be "don't buy an Ohio bus" or a bus from anywhere in the NE US ( especially not from the shores of Lake Erie, where my bus hails from).
01-16-2022, 01:23 PM
This is the worst I’ve ever seen!
OPs pictures don’t look terrible. About how mine did. But I’ve now spent months rust prepping and having to replace all types of stuff.
01-16-2022, 03:13 PM
Coachwork: IC / Amtran
Chassis: CE300
Engine: International T444e
Rated Cap: 23
Why is the underside the only picture they couldn't supply you? That makes zero sense. Unless, of course, it makes perfect sense to the seller for... reasons.
Go away. 'Baitin.
Our Build: Mr. Beefy
01-16-2022, 04:43 PM
Year: 2005
Chassis: FS65
Deelya.....I'm curious...what did you guys do?
01-22-2022, 06:31 PM
Going from the pics. You provided, it looks really clean. That is just surface rust.
GO FOR IT.
01-22-2022, 06:49 PM
Year: 86
Chassis: Ford B700
Engine: 8.2
ok lonejack where are you and what experience do you have to give that opinion/advice?
