Old 05-22-2017, 09:02 AM   #1
Question Proper way to dry out a crawl space?
The old neighbor has a crawl space under his house and it has been wet under there. He has a box fan 20" blowing air underneath through a 24x48 " opening. Wouldn't he be better to turn it around and draw out the air? 38X24 FT CRAWL SPACE ABOUT 2 FT OFF THE GROUND.darn caps!
Old 05-22-2017, 09:33 AM   #2
Njsurf73's Avatar
Chassis: Bluebird
Engine: 5.9 Cummins 24v
Rated Cap: 72 pax
I would "pull" the air out, but you have to make sure there is air coming in. A perfect scenario would be an opening across from where you are drawing air out.
Old 05-22-2017, 04:12 PM   #3
Engine: TE 444
Rated Cap: 12
Put a dehumidifier in it
Old 05-22-2017, 05:00 PM   #4
Stu & Filo. T's Avatar
Coachwork: Crown / Pusher
I've got one of these,
RIDGID 1625 CFM Air Mover-AM2560 - The Home Depot
Old 05-22-2017, 08:55 PM   #5
superdave's Avatar
Chassis: thomas
Engine: 8.3 cummins
Rated Cap: 11 window
make sure he has gutters on the house with down spouts. there should be plastic on the ground, you shouldn't need a fan just vents on each side of the house
my build pics
Old 05-22-2017, 08:58 PM   #6
if the crawl space is getting that much water you may nmeed to think about french drains and a sump pump similar to northern basement drainage.
Old 05-22-2017, 09:34 PM   #7
We use one of these at the shop to pull smoke away from the laser engraver... WAY OVERKILL!
But I read some reviews where people are having pretty good luck ventilating various areas.
