Originally Posted by Snewo
I can't find a cheap small heater like that with 1" line, which is why I'm asking if it's OK to step it down to 5/8". I do not plan on going through the floor FWIW, I have hose coming into the compartment behind the driver's seat and I'm planning on doing all clamping etc in the compartment.
so you have your heater line looped after your front heaters? or you tore out all your front heaters? im a bit lost..
if you took out your defrosters and your front heaters then buy 2 heaters.. one to put your defrosters back to work and then one for your heater..
the answer though is yes you can step your line size down to 5/8", you wont hurt anythuing at all by doing it.. if you do try and put 2 heaters in series, the second one may lose a little capacity at idle but not too bad..
if you looped your heater lines Behind your existing defroster system you can still step down to 5/8 but if you have the factory defroster as the first in the flow.. at idle you may lose a good bit of capacity on your new heater, but above idle youll be just fine...
I ran a parallel / series flow system so that I could have a 1 inch trunk and then pull each 5/8 heater off of the trunk... for more than a couple heaters this type system is the only way to go if you want to run 5/8.. but for just 1 or 2 you can keep it simple, step down and go..
