07-01-2020, 05:39 PM
skoollie business idea - tell me what you think
hey all!!
i got an idea im considering and would like some feedback.
could i sell it? would you buy it? would someone buy it?
i've been thinking about making a "Skoolie Kit". not everything, just the carpentry.
i think i could turn any floor plan into a CAD / CAM file and and cut out any bus interior on a CNC router table.
the computer can label the parts and draw up construction plans. you could flat pack a bus in a few boxes, ship it and assemble like you bought it at IKEA.
the pieces would assemble and be intertwined so that everything is connected together. hvac, wiring conduits pre planned.
cost wise for a bus... maybe it takes 15 sheets of plywood. 15 x$100
maybe 15 hours machine time - 15 hr x $100
double that number for overhead.
then shipping
assembly
would you pay $6K-ish for a machine cut cabinet like interior?
07-01-2020, 05:43 PM
Engine: Chevrolet 427
That's an interesting concept for sure. Me personally, I'm trying to go cheap as possible, so 6K would be way over-budget for my wood work. But then, I've also never made a cabinet and I'm going to learn-as-I-go.
07-01-2020, 05:46 PM
I like it. I definitely would buy some pieces for my lil 5 window shorty.
07-01-2020, 07:22 PM
Coachwork: Winnebago
Chassis: Ford F53
Engine: Ford Triton V-10
Rated Cap: currently 2
I like the idea. The catch may be building a library of designs specific to different models of buses.
07-01-2020, 09:48 PM
and either you or the customer screwed up the measurements. What then?
useless pieces at that point, no?
07-02-2020, 08:18 AM
all busses vary.. they all vary from year to year to manufacturer to individual unit.. they really are cut-to-fit, you'd almpst need to build a laser measuring system that you would send out and then hopefully get back.. something cloud based where a person getting it couldnt use it if you remotely disabled it.. it would measure the interior of a bus and then theyd send the device back and get their plans and pieces..
07-02-2020, 09:14 AM
What Cadillackid said!
Imagine my surprise when I learned if you added up all the total variances of the major stations (stations are how/where aircraft are measured at from tip to tail for precise reference) on my beloved UH-1H something as precise as a helicopter could be almost 2" shorter from one to another!
Now, if a given bus could come to you for precise measurements you could build the kit and pack the boxes on their bus and away they go...
Otherwise I fear much sadness between you or the customer with that...
Another anecdotal problem (my data set of one...)
Where my bus body welds over the Freightliner wheelwells -- the multi-layers of metal on metal have generated exfoliation or layer corrosion -- the result is ¼" or more of uplift in my floor just behind the wheel wells. The Thomas floor itself is still very solid -- it's just the Freightliner box tubing below it that's gone to hell -- the freightliner tubing is superfluous with the thomas body on top so not much to repair metal wise but this would bugger up fitting a floor to ceiling panel for sure... That wouldn't be your fault but it would be an unhappy customer...
(I notice a ¼" of uplift looking at the floor cause I've looked at metal framing for 30 years (if it was an aircraft, I'd ground it!) but most people wouldn't see it till something didn't fit...)
07-02-2020, 10:52 AM
I'll skip the political correctness aspect--
It won't work no matter how much money you throw at it.
07-02-2020, 09:12 PM
Not a big enough market to be viable.
But if including the high end #vanlife crowd, yacht renovations, cargo trailer conversions
prolly still not enough.
Have to measure yourself, for sure.
Each job a once-off.
Would be a lot more work and lower net income IMO than almost any other skilled profession.
But if you love doing it, had a real drive with passion, maybe could evolve into something sustainable?
07-02-2020, 11:29 PM
1. Too many variables to get any economy of scale.
2. Too small a market and not enough real spenders in it.
3. Not much savings for the customer, especially if anything doesn't fit.
The van guys already have companies trying to provide prefab stuff for them that "bolts right in..." There's a Sprinter bathroom kit that, surprise, surprise, doesn't fit well and makes poor compromises. They are a much bigger market, and apparently hard to address with kit/prefab products.
So many reasons why this wont work on the merits, but just look at it as a business, or as a banker would do. Say it costs $10k to get this business going. Probably takes ten times that, but no matter. The key question is- is this business likely to return that investment sooner in earnings or increased value of the business than if we invested the $10k any other way?
That's the opportunity cost hurdle, and this idea won't clear it...
07-02-2020, 11:54 PM
thanks everyone for the input!!!
i agree! with everyone
measuring is a problem. i've been looking at the laser scanners like Faro and wow! are they cool.
limited market is a problem. skoolies are cheap bastards that don't want to pay for anything they dont have to. i am a prime example of this.
the simplest idea is generic pieces that don't require anything but a flat floor and straight wall. you can go get pieces form ikea or a big box today and use them. the bed and lower cabinets wouldn't need bus measurements to work.
upper cabinets, bulkheads, bathrooms would need some more advanced measuring that that maybe could be done with a low tech jig.
while the generic pieces are meant for a bus.... its not custom...they will need to be adaptable.
if someone brought a vehicle to my property, that would be the start of going custom, using laser scanners, matching interior profiles to cabinets.
with the right CAD software, you can be a one off job shop. the first bathroom with a pocket door will take many computer hours assigning joinery properties, hardware properties. the second pocket door bathroom will only need to change the dimensions. if you are curious about CAD, check out
I'm still daydreaming.
keep your comments coming!
07-03-2020, 04:53 AM
The latest iPads have lidar built into them (basically radar using light). I'm not sure it would be accurate enough for 3D measurement (or cheaper than a dedicated scanner), but maybe.
I wonder if you could use CNC routing to shape custom blocks of XPS foam board that fit the ceiling curvature (either by shaping thicker pieces or kerfing stuff with the same thickness as the ribs). It seems spray foam costs about twice as much per board-foot as does foam board, so there's a potential 100% markup there, more if you can get a bulk price on the foam board. The fit blocks would be nearly as effective as the foam (more effective compared to spray foam jobs that don't entirely fill the spaces) and would be much easier to install DIY.
07-03-2020, 06:44 AM
its like building cars.. every fender, door, hood, trunklid, etc are all built with slotted mounts so you can straighten the body lines to match the differences in the frame / unibody after the car comes off the main assembly line..
07-08-2020, 04:24 PM
Doing the woodwork is something someone without much experience can learn fairly easily. Now if you can do a diesel fuel injector swap cheap online, and rebuild a turbo, or fix the plumbing leaks.
What could be a better idea is to have a website where people can look at different cabinets and textures and layouts and you can send them plans so they can diy it.
So no precise measuring and shipping materials involved.
07-08-2020, 05:58 PM
Year: 2015
Coachwork: Chevrolet
Chassis: Goshen Shuttle Bus
Engine: 6.0 Chev
I like your concept. I have read all the above comments and l agree with alot of them. I think that the customer base you would be serving would be small. Most people taking this on already have build abilities, and will want to do it much cheaper themselves. I think your product idea would be for the non mechanical non building people or the " l want it without doing it cost doesn't matter " people. The measurements would be a bugger for any bus as even every build is not precisely perfect.
Maybe you could do a drop it off and you would build the interior option?
If l can't fix it, it's not broke!
Duct tape!! Who knew!!
If l don't have that tool... they don't make it!
07-08-2020, 10:01 PM
Coachwork: Freightliner
If you had the ability to scan and cut custom cabinets I would consider driving out for a few custom pieces. But I wouldn't want to spend $6k on a whole build.
07-08-2020, 11:00 PM
Engine: DT530
Even different areas on the same bus don't match. I cut a perfect template for my first cabinet and had to adjust it for every other one I made. Very frustrating. Even more so if I paid 6k.
07-21-2020, 01:32 PM
thanks for all the feed back!
so...
i've been chasing this idea down and here is where i am at.
there is no economical way to scan a vehicle for measurements.
the 2 suggested lidar methods...#1 lidar sensors - create point clouds, then convert to cad. its doable, but not cheap. to buy the sensor($50k+) this is the BKL360 or the BLK2Go. very cool stuff! the software on top of the sensors is pretty expensive as well. for $100K you could measure a bus to with a 1/16th of an inch.
not very practical
the second method via the new lidar ipads. this is more doable, but not in house. you have to scan you scans and send it off to be converted to cad for a fee.
maybe more practical - to new to know.
the limitations however is that the software that build the cabinets doesnt care. it assumes that you are connecting a flat backed cabinet to a flat wall. this is why carpenters have jobs.
so the idea of a laser cut interior is nice but not real practical. it could be done, its just not cheap or practical at the moment. and you would still have to shim it to the insides of a vehicle.
so what could i do?
right now, i see making kits and furniture. they may or may not need some trimming/shimming.
i could take your floor plan, from a drawing or sketchup and turn it in to a digital 3d model. break that model into individual components. Figure out the joinery of everyone of the components. nest it all the parts on as few sheets of wood as possible and cut out.
voila.... precut skoolie kit.
bunks, storage, closets, bathroom, counters, couches,
do you want:
40 or 50 dove tail drawers? no problems
island bed with lift up storage platform? no problem
secret hidden storage compartments? no problem
you want it in a week or less?now we are talking!
**the upper radius curve of the bus will have to be close or test fit individually.** the rest assumes you are working off a flat wall or floor.
software is able to model the parts (projected up from a 2d floorplan). cnc is able to precisely cut out the parts. the only parts that would have to be figured out onsite would be a bulkheads and upper cabinets.
you could turn a digital model into the real thing in a few days time. not weeks or longer. with minimal carpentry skills.
the cad model would give you a list of all hardware... a bill of materials.. the nesting software would stack the parts to minimize waste and you'd cut out everything at once.
I'm going to try and model this out and see what happens.
please comment and Stay tuned!
07-21-2020, 01:45 PM
If this overall idea could become a viable "business"
and that is "a big if" afaic
even just in the sense of providing a decent living for the people involved, who enjoy that specific work, not comparing to other more lucrative niche markets for their skills
then I reckon forget the high tech*, forget the idea of mass markets
pursue local markets where wealthy people want to get into #vanlife and are willing to pay the world for custom once off work.
You will need to go to them, I'm thinking Bay area, San Jose environs, maybe Seattle, maybe Portland or Austin.
And forget skoolies, think Euro vans like Sprinters.
Might even make money buying low, converting and selling high, but very risky, the high-touch design taste and luxe quality finish standards would need to be top-notch.
*except where the up front investment would pay for itself in 1-2 gigs, compared to the old-school ways
07-25-2020, 11:16 PM
Chassis: All American RE
Engine: Caterpillar 3126B
Okay, so I'm new to the Skoolie world, but I've solved lots of design problems over the course of my life. I think there is a way to make this work.
The obstacle that most people see is the variations in bus dimensions, particularly at the roof line, but also at the wall. Here's the trick. Don't try to fit the existing roof line or wall line, but create a comfortable margin that allows the components to all line up from the floor, leaving a small, manageable gap at the wall and ceiling, then fill the remaining cavity between the component ceiling and the actual bus ceiling contour with insulation.
With this approach, you might lose something in ceiling height and maybe a couple inches in the aisle between the walls, but you would gain components that fits most busses pretty well, once a nominal ceiling height is determined.
Am I missing something, or why would this not work?
