05-25-2021, 08:34 PM
Year: 1974
Chassis: "Atomic"
Engine: DD 8V71
So...what is this old bus?
Hi all,
I've not seen a roof profile like this, so I wanted to see if the group here could identify this 1960s (ish) bus with the bumped up roof and the little standee windows. The maker plate inside has been removed, so all that's left are the rivet holes and the outline of the plate. It's a Ford and, we guess, 1960s...but that's all we've got for now.
Guesses or thoughts? Thanks!
05-26-2021, 12:27 AM
Year: 1954
Coachwork: wayne
Engine: cummins 12 valve
the bus is a ....
I am fairly certain this is a 1963 high roof Superior. look at the side and the rear wheel wells. google '1963 high roof superior'
william
05-26-2021, 06:31 AM
Year: 1974
Chassis: "Atomic"
Engine: DD 8V71
william
Right on! That's amazing, William. That search gave me all of one applicable result, a photo on Pinterest, but it's absolutely the same bus. It doesn't look like it's a very common beast...so how the heck did you know this? I'm impressed and thankful, sir.
Here's the photo I found, with your search terms:
05-26-2021, 12:48 PM
Year: 1954
Coachwork: wayne
Rossvtaylor- how did I know
Okay, partly cause I‘be seen that odd raised rear roof before. The last panel on the side the ribbed part, that is inline with the windows is a superior thing. The wheel arch in the rear is also very much superior. The ford body was after 1957. The ford part looked around 1963, so I guessed. 1963 superior high roof and pressed ‘enter’.
I have a 1954 ford/Wayne and I waste too much time looking at older busses. Pretty much, by 1963/1965. No one except crown and gillig have rounded roof lines.
William
05-26-2021, 02:19 PM
Year: 1974
Chassis: "Atomic"
Engine: DD 8V71
Thanks, William. That tip about the ribbed section behind the windows is a good bit of info.
Well, her name is now Ashlie...since we bought her from Ash Fork. It seems fitting. Once I figure out what engine she has, I can narrow down the year from the current "1961-1966" range we know based on the grill design.
06-06-2021, 11:49 PM
Year: 1974
Chassis: "Atomic"
Engine: DD 8V71
I finally had a chance, today, to winch her out of the sand and tow her home. It's interesting that she's a twin stick...one for shifting the transmission and one for the intermediate gear box (range selector). I look forward to digging more into this and identifying the actual makes and models of these parts...which I'll share when I do.
I also need to ID the engine, which will help me narrow down the year of this old gal.
Before pulling her out of her current resting spot, we had to detach her from the shed roof that was bolted to the side. Buses are meant to be free...
06-07-2021, 12:27 AM
Engine: C7 Cat
Attachment 58211
Wow Ross you are a beast! That's some commitment.
Got to love The classics.
Cheers
06-07-2021, 12:33 AM
Year: 1974
Chassis: "Atomic"
Engine: DD 8V71
Cheers
Beast mode activated! Haha!
Both my wife and I definitely have a soft spot for the vintage and the unusual...and this one ticks both of those boxes. I think it's my favorite bus. But I say that with every bus.
06-07-2021, 12:46 AM
Engine: C7 Cat
Agree with you there for sure, that high top looks awesome.
Good on you both for pulling that one home.
Cheers
06-07-2021, 04:51 AM
This is fantastic, really looking forward to this conversion/restoration.
06-09-2021, 04:02 PM
Coachwork: Bluebird International
Engine: T444e
Rated Cap: 35
I like the lines with the old round corners too.
06-09-2021, 05:56 PM
Year: 2009
Coachwork: Gillig
Chassis: G27E102
Engine: Cummins ISL 280
Rated Cap: 26,000 lbs
Yes. I’m normally much more the cubist type, but this one is gorgeous
07-14-2021, 12:47 AM
Rated Cap: 66pax
The high-headroom body with extra windows on the side, combined with the space for a rollsign on the front roofcap, are dead giveaways that this was originally in military service. Lots of these were repurposed for other government uses later on in their careers.
07-14-2021, 07:47 AM
Year: 1974
Chassis: "Atomic"
Engine: DD 8V71
Thank you for this - that fits with my gut thought, after investigating some. Our old late '30s military transport bus also has the standee windows above the regular windows.
I sure wish the old roll sign were still there, to help provide a bit more history...
Thanks, again!
