Old 02-13-2017, 04:55 PM   #1
30kdays's Avatar
Chassis: Cadet
Engine: 5.7 350 gas
Rated Cap: 35 Passenger or 14,500
Suggestions for door lock?
Any suggestions to make a door lock for our front door?
30kdays is offline   Reply With Quote
Old 02-13-2017, 05:42 PM   #2
I have a long pad lock at the bottom of my by fold door. Not perfect but it works.
My bus is under couple feet of snow I would take a photo.
Gordon
Tootalltechie is offline   Reply With Quote
Old 02-13-2017, 05:50 PM   #3
Chassis: TC 2000 bluebird
Engine: 5.9 cummins
I used a three point lock from Atlantic Shed.
Bill
miltruckman is offline   Reply With Quote
Old 02-13-2017, 08:33 PM   #4
Coachwork: BB
Engine: Cummins
Rated Cap: 25.999K
I had my factory lock re-keyed by a lock smith. 10 dollars and 3 minutes....
SDR76 is offline   Reply With Quote
Old 02-13-2017, 09:00 PM   #5
30kdays's Avatar
Chassis: Cadet
Engine: 5.7 350 gas
Can you elaborate on this? When I removed the door opening mechanism it seemed to be connected to the lock. So, how did you get yours locked after removing that?
Old 02-14-2017, 06:01 AM   #6
Coachwork: BB
Engine: Cummins
Rated Cap: 25.999K
Mine is a on a 1990 BB. It has an assembly that is held into the door by 4 screws. Mine is basically a giant "D" Ring, Which twists and locks to the other half of the door. It has a little lock tumbler that stops it from twisting when locked. I did not have factory keys, so i took the mechanism out to have lock smith find a new tumbler, and they were able to just whip out a new key instead. Does yours not have a factory lock of some type??
Old 02-22-2017, 10:33 PM   #7
30kdays's Avatar
Chassis: Cadet
Engine: 5.7 350 gas
The factory lock mechanism was defeated when I removed the giant factory door opener that's on top of the dog house (inside engine bay).
Old 07-12-2017, 06:58 PM   #8
I just received my order from Atlantic shed. On the back of the latch mechanism is stamped "spep.com"
Turns they are manufacturers / suppliers of latches & locks. Check them out at
http://www.spep.com/Index.html
Old 04-28-2019, 05:28 PM   #9
HazMatt's Avatar
Chassis: IH 3800, 8 window
Shiny! Cool link, thanx!
