Old 10-20-2020, 04:56 PM   #1
Wmortimer's Avatar
Chassis: TC 2000
Rated Cap: 29
TC100 Headlight replacement/additions
Any suggestions for brighter headlights for a 2000 Bluebird TC1000? Led? Halogen? Add light bars? Boy oh boy are the OEM lights D.I.M!
Wmortimer is offline   Reply With Quote
Old 10-20-2020, 05:06 PM   #2
Chassis: TC RE
Engine: 8.3 Cummins MD3060
Not sure the original layout you have. Mine is a single light on each side. This is what I am planning on using. I have done a lot of research and I think this will be the best solution for me. I also plan on adding as big of a light bar as I can find to the space above the windshield for use out on the open desert roads.
https://www.amazon.com/dp/B0784NV3FK...v_ov_lig_dp_it
JackE is offline   Reply With Quote
Old 10-20-2020, 05:17 PM   #3
Wmortimer's Avatar
Chassis: TC 2000
Rated Cap: 29
Oh cool! Let me know what you think!
Old 10-21-2020, 06:29 PM   #4
Chassis: TC RE
I won't be thinking anything for a while. At $400 for headlights, they won't get bought until I'm about ready to put it on the road. Late next spring at the earliest.
Old 10-21-2020, 07:03 PM   #5
Truthseeker4449's Avatar
Chassis: MVP ER
Engine: CAT 3126
A bit spendy, but from what I've seen in reviews and comparisons, JWSpeaker makes some of the best LED headlights on the market.
I have LED headlights from Truck-Lite, which I felt was a better compromise at $160 for pair. Mine are the 7" round style tho.
A note about lightbars for the OP, they're generally not highway legal or very frowned upon. But a good pair of LED Headlights should give you the light you desire.
Truthseeker4449 is offline   Reply With Quote
Old 10-22-2020, 10:49 AM   #6
Wmortimer's Avatar
Chassis: TC 2000
Rated Cap: 29
Yeah, i thought that might be the case with light bars. I figured if I used one, I’d mount it very low and only use it on dirt and park road situations.
I’ll check out truck-lite
Old 10-22-2020, 12:26 PM   #7
Coachwork: Blueburd
Chassis: International S1800
Engine: 9.0L International Diesel NA
Link to headlights???
Rochey6957 is offline   Reply With Quote
Old 10-22-2020, 12:43 PM   #8
Chassis: TC RE
JW Speaker
Trucklite
https://www.amazon.com/dp/B007ED7HNY...v_ov_lig_dp_it
Here are a few others I looked at and may give a try when I want to waste some money, including a Chinese knock-off on the Trucklite's.
https://www.amazon.com/dp/B081GYB7SD...v_ov_lig_dp_it
https://www.amazon.com/dp/B00U472EA8...v_ov_lig_dp_it
https://www.amazon.com/dp/B07G31G4VB...v_ov_lig_dp_it
