Old 04-10-2024, 12:28 AM   #1
TCS-225 - Compressor Switch For Thomas
Hey everyone,
First post and just got my first Skoolie.
I just got a 2004 Chevy.
Can someone tell me what does this rocker switch do?
"TCS-225 - Compressor Switch For Thomas"
https://www.tacbusparts.com/TCS-225-...tch-for-Thomas
Also do they make a Cassette toilet that can be used on the road and also be hooked up to a sewage connection?
Thanks
ShadeyJones is offline   Reply With Quote
Old 04-10-2024, 03:28 PM   #2
Jolly Roger bus 223's Avatar
Year: 86
Chassis: Ford B700
Engine: 8.2
looks like it turns on your A/C compressor
Old 04-10-2024, 05:45 PM   #3
That's what im thinking but i don't have a second AC, like a roof or rear cabin one.
I only have the one built in AC.
Old 04-10-2024, 08:05 PM   #4
not sure what that switch would be usied on a van cutaway bua... on a full size thomas.. those are luggage compartment light switches... not "compressor"..
Old 04-10-2024, 08:11 PM   #5
I havent seen a cassette toiler that was dual.. geberally the purpose of one is that you have a small tank you empty .. people like them as they can be portable toilets used in everything from vans to tents..
idea being that its supposedly cleaner to empty the cassette than use a sewer hose from a built in black tank.
Old 04-10-2024, 09:07 PM   #6
There is a switch that says lights next to that one and it turns on the 6 Roof Luggage rack lights. Is it possible that is wiring if you install an optional rear ac/heat unit?
Old 04-10-2024, 09:15 PM   #7
I was thinking of this unit attached.
It has a waste tank cap towards the rear. I put in a gate valve and then i can extend it out the side and make it so i can hookup to a sewer hookup to empty it, and close it off while on the road just for #1.
Old 04-17-2024, 09:09 PM   #8
Found out what that switch does..... It turns on a small light in the overhead compartment where all the wiring and fuses are, lol
thanks everyone
