Originally Posted by Mountain Gnome
And I always thought it was the other way around....
Warm moist air condenses on cold pipes!
Or maybe the cold weather makes your pipes shrink and leak at the joints?
But what do I know...I wasn't there
You are quite right --
Hmm, well as I finish my coffee and wake up...
Being a waste drain to my septic, the pipe is not always running water -- and it's not always hot water. So it's cycling hot and cold water to no water depending on usage...
And it could be (probably is now that I think deeper) the crawl space is probably high 50's at the coldest while cold toilet, sink rinse, water from my well is low 40's in the winter...
But the drips are crystal clear water -- I made sure of that! -- so it's not a joint leak.
