Thomas Pneumatic Door
Hey everyone!
I have a 2003 Thomas bus and the wiring was a total mess so I pulled a bunch of the safety stuff out of it (door alarms, flasher lights, etc). I had no issues with anything until I went to open and close the pneumatic door. Two of the wires running to the door switch used to run to the flasher lights. Those now don't run anywhere. There are now 4 wires running to the switch. One runs to the ignition coil for the positive (when the key is on) and the others all seem to be grounds. Putting all that aside, does anyone know how the solenoid works (next to the air cylinder actuator above the door)? There are 2 small wires running to it. I tried putting 12v to them and immediately blew a 10A fuse I was protecting the circuit with. Now that the flashers and other safety stuff is gone, I'm really just trying to isolate the door system and try to operate it (still using the pneumatic system) in the simplest way possible. Thanks!
