Old 09-11-2021, 01:40 PM   #1
Too much rust?
Hi, I could use some advice. I know rust on the chassis is bad, but I don’t know how much is too much. Could you please give your opinion of this bus I am looking at to purchase?
9C63E363-578B-462A-8F3B-D00C1ED37C97.jpeg   C4C5366C-A840-4133-A82F-65E5EBEEF4A4.jpeg   1E9F6E33-526F-4F2C-80A6-BEED5F739272.jpeg   279FE78D-0535-4CA2-BBCA-6A61B5FE53CC.jpeg   462A2E55-546E-4A67-AE33-E5C0C0561EBE.jpeg
F569F160-39F9-4C37-9C72-42420BEC9EEA.jpeg   F09AC59F-352A-4446-9C43-67F2F39D82F0.jpeg
Kavita is offline   Reply With Quote
Old 09-11-2021, 03:50 PM   #2
That's all minor surface rust. A chassis is made from very thick steel and takes a long time to rust to the point where it's structurally weakened. Your big concern is rust in the body, which is the steel box that is sitting on top of the chassis rails. Your pictures show only the floor of the body, but there is little to no corrosion there. Although the bus is fairly obviously from a part of the country that uses salt on the roads, it looks like the previous owners cleaned the underside from time to time.
You may have rust concerns with the exhaust, which is expensive to replace.
Old 09-11-2021, 04:30 PM   #3
Thank you for your response. That is super encouraging.
Old 09-12-2021, 05:40 PM   #4
Year: 2009
Coachwork: Girardin
Engine: 6.6 turbo diesel
Rated Cap: ?
The amount of rust on my bus makes this bus look pristine! And...although there appeared to be quite a bit of rust on my bus, my mechanic said it was all superficial and nothing to worry about. Btw...i have known him 20 years and he is very honest and knowledged. So IMHO you are looking good. Elizabeth.
Buster Junior is offline   Reply With Quote
Old 09-12-2021, 07:17 PM   #5
Thank you so much! I am going to arrange to take the bus to a mechanic to get the rest checked out. I hope it will be good so I can purchase it and get started!
rustbus
