Old 05-12-2024, 06:56 PM   #1
too much rust?
Please give me an opinion on this! The last picture might look more red than it actually is because of lighting.
alannabirch is offline   Reply With Quote
Old 05-12-2024, 07:23 PM   #2
thatsd pretty rusty... if it was a bus i already owned and converted id probably keep driving it.. but if its a bus you havent bought yet, I wouldnt..
Old 05-13-2024, 05:15 AM   #3
Check out this gallery to see how bad my rust was and what I had to go through to repair the worst of it. Your bus here is probably not quite that bad, but it certainly isn't good. It would be best if you kept looking for a bus with much less (ideally no) rust and spare yourself all the extra work this one would entail.
FWIW the bus is probably structurally sound - i.e. the chassis is not going to suddenly collapse on you in the middle of a drive. Most of the extra work you'd have to do would be on the bus body, the part that is sitting on top of the chassis rails. The body is made from sheet metal which being thinner than the steel of the chassis is affected by rust more quickly, and is likely completely eaten through in all the usual areas (wheel wells, rear door and corners, step well etc.). You're also showing severe corrosion on the exhaust pipes and replacing that stuff can get pretty expensive.
Old 05-13-2024, 10:07 AM   #4
Year: 1954
Coachwork: wayne
Engine: cummins 12 valve
yup, what he said
If you own it already... work with what you have. The body is the work, the chassis is okay. Rust like that means check the metal brake lines and parts. Rust makes for extra work and expense when working on brakes. Like when the bleeder screws are rusted so bad they break off... then it is caliper replacement time.
anyways, If you dont own it.... I see lots of busses for sale with much much less rust.
william
Old 05-14-2024, 06:13 PM   #5
thank you all for the feedback. this is not my bus, but one I am looking to purchase, already converted.
Old 05-14-2024, 10:38 PM   #6
Chassis: Chevy P30
Engine: Chevy 6.2L Diesel
Then I would politely skip it, and keep looking, honestly.
It's not going to break in half or anything, but rust is a cancer that is pretty much impossible to stop once it starts to take hold. The bus those pics are from has a much more finite lifespan than something else.
Albatross is offline   Reply With Quote
Old 05-15-2024, 09:10 AM   #7
Chassis: Ford E450
Engine: V10 Gas
Ask yourself: how much have I researched skoolies, and how many buses have I looked at so far?
Unless the interior is the skoolie of your dreams and you have a metal fabrication shop, turn tail, and run like the wind. Better deals await, regardless of the offered price.
Although I admire the bravery of my friend MagnaKansas, most newbie skoolie owners have the desire, but not necessarily the money, tenacity, determination, stubbornness, grit and gumption to tackle structural work like that.
Spend time looking at his album and contemplate the many hours you will spend in soul-sucking work underneath that vehicle to render it mechanically sound before leaping.
Old 05-15-2024, 05:15 PM   #8
Ronnie's Avatar
Engine: 345 international V-8
Considering I have pulled two buses now out of the woods to rebuild and make skoolies out of, that much rust would even make me say no.
Old 05-15-2024, 06:26 PM   #9
That's kind of even worse than buying an unconverted bus with that much rust. Unless they have a detailed build thread somewhere, you really have no way of knowing whether they dealt with the body rust properly or not.
