Originally Posted by magnakansas
yes you can..........now go find the specifications and limitations of your bus/transmission in dont over load it.
william
THIS!
Some more info on the bus in particular would be useful in helping to determine this. A simple GVWR on a body plate does not help if you don't know the empty weight (or total weight as converted) or what the trans is rated for. And the trans is usually the weak link in such situations. I would highly recommend an auxiliary transmission fluid cooler if not already equipped, if it is doable.
OP's 8.1 / Allison combo sounds a lot like a late-90s / early 00s Chevy / GMC Class 7 chassis, or MAYBE a similar vintage Savana/Express van chassis minibus. On the latter, a GM dealer should be able to find this info for you if there are no postings of it on the vehicle anywhere. If nothing else, identifying the trans model you have can get you some info from the trans manufacturer (in this case, Allison).
In theory, you should be able to, but for instance, the P30 motorhome I live in is only rated for 2,000 lbs towing capacity. Granted, it is likely a TH400, being powered by a 454 big-block Chevy (the 8.1 Vortec's older brother -- the 8.1 is a 496, the stroker version of a 454), but the vehicle's empty and loaded weight count towards the transmission's rated capacity. Point being, you can have all the engine in the world, but if the trans can't take it, it is what it is. This is the reason that most commercial trucks are manuals. An Alllison unit should be able to handle quite a bit more than a typical light-duty automatic, however.
