Old 07-12-2019, 01:45 PM   #101
OrionsComfortBus's Avatar
Coachwork: International - AmTran
Engine: DTA 360
Rated Cap: 25,500 lbs
Thank You Both for the replies.
Christopher, I will be sure to pass that bit of information on to the shop. Seems it will save a bit of time trying to figure it out.
The price of freedom is eternal vigilance. - Thomas Jefferson
Ongoing project of maintenance and replacement of things in and on the Comfort Bus https://www.skoolie.net/forums/f9/up...bus-24772.html
OrionsComfortBus is offline   Reply With Quote
Old 07-15-2019, 10:36 AM   #102
Engine: DTA 360
Christopher, re-reading your reply has me wondering if the tailshaft seal and bearing have to be replaced after being pulled out OR are they undamaged and can be reinstalled.
Old 07-25-2019, 02:13 AM   #103
Engine: DTA 360
Got bored tonight, went out into the bus and detached the instrument cluster from the dash. I then changed the D.I.P. switch settings for the speedometer. Took about 5 minutes overall. Went on a test run and Im happy with the results. The speedo now reads 63 at 60 on my GPS. Thats fine with me since it will give me a little "comfort zone". I can be doing 65 on the speedo but im actually going a little slower.
Old 07-25-2019, 02:20 AM   #104
Engine: DTA 360
Old 07-27-2019, 04:24 AM   #105
Engine: DTA 360
Found a pretty good deal on Transynd fluid at http://www.madjackdiesel.com
I saved about $20 on 6Gal of it versus the cost at Amazon.
I know its expensive but I wanted the first fill of the MT643 to be the correct fluid.
Old 07-27-2019, 05:35 AM   #106
HazMatt's Avatar
Chassis: IH 3800, 8 window
Good call!
You can always cheap-out down the road... [emoji57]
Old 08-03-2019, 06:36 PM   #107
Engine: DTA 360
Got the 6 gallons of Transynd and 50 foot x 2 foot roll of Reflectix for the bus.
IMG_20190802_203513752.jpg   IMG_20190802_203528949.jpg   IMG_20190802_203354129.jpg
Old 08-03-2019, 06:38 PM   #108
Engine: DTA 360
Originally Posted by HazMatt View Post
Good call!
I don't think I ever will "cheap out" with the transmission fluid.
Old 08-05-2019, 08:26 AM   #109
Coachwork: American Cargo 14'L x 7'8"W x 7'H Box
Chassis: Ford E350 Cutaway
Rated Cap: 11500 lbs
TranSynd is good stuff. It noticeably reduced the converter slippage and resulting heat generation in the AT545 of my International 4700 box truck.
alpine44 is offline   Reply With Quote
Old 08-05-2019, 08:37 AM   #110
I got enough to do a couple fills on my 545. A transmission isn't something to cheap out on.
In FL our bus regulations actually specify all buses must run Transynd when in service. Its probably the heat here.
Old 08-05-2019, 11:56 AM   #111
Engine: DTA 360
Got the Transynd delivered to the shop.
Work on the bus has not started but I've been assured that it will be done before the thirteenth of this month.
Old 08-05-2019, 08:54 PM   #112
They like to cut things short! Not much time in that shedule for the "oops" factor.
Old 08-06-2019, 01:36 PM   #113
Engine: DTA 360
Shouldn't take too long. Perhaps 2 days for the swap and 2 more for the drive shaft shortening.
Old 08-06-2019, 09:08 PM   #114
The bearing is t damaged assuming you use the correct tool to pull it, the seal I never re use, I have the tools but Iím 1400 miles away from home, hopefully yours comes the right way so you just screw in the sensor from the 545 and go
Old 08-06-2019, 10:17 PM   #115
Rivetboy's Avatar
OK ECCB, here is my question, How long would tou run standard ATF in a new rebuild AT 545 before you drained it and upgraded to transyn? Their is 10 miles total on the trans at this point. Thanks !
Rivetboy is offline   Reply With Quote
Old 08-06-2019, 11:18 PM   #116
Engine: DTA 360
Just my thoughts. Why use anything else. It's a Allison, use the fluid designed for it. With standard ATF it might run hotter, not shift as smoothly and require changing at shorter intervals. Running hotter with harder shifts can lead to the trans breaking down sooner.
I watch OneLoneyFarmer on YouTube. He uses very specific fluid for his tractors. Hygrade I think. He says the tractors operate better . Quite a few others will only use full synthetic for lube. I personally have used full synthetic oil in the bus engine, rear diff and now the trans. It's expensive but well worth it.
If you expect to put slot of miles on it, give it the best chance of going the distance.
Old 08-07-2019, 06:32 AM   #117
its the type of fluid, not the brand. TES-295 fluids are approved for the newer allisons..
the older allisons were built and designed to run on standard DEXRON III ATF.. for severe duty they actually published Specs to run Rotella T 15W40 Motor oil in them.. the idea being that at the time the motor oil maintained a higher level of lubricity at higher temperatures and didnt break down like standard ATF..
I run Transynd in my allison 1000 as its a newer trans and was built for synthetic fluids and as well as it extended my warranty from Suncoast to 36 months unlimited miles if I run Transynd..
Heat is the biggest killer of Transmission fluid.. when I shoot the side of my MT643 after 400 miles on the road in summer its hanging out in the 195-200 degree range.. regular ATF will last a long time at those temperatures.. im running a part synthetic.
would trandsynd help it? probably so, but a conversation with international when i got a couple parts was alongthe lines of transynd will never hurt an older transmission but high quality regular or part synthetic ATF is also good..
whats going to make your transmission last the longest is keeping it in its comfort-zone temperature wise.. dont get it hot.. transmissions Love to operate between 120 and 190 degrees.. pretty much any fluid is good till you get into that 210-220 range..
if you run consistently above 200-210 run transynd as it will hold up much better than regular or part synthetic.. but ultimately try and keep that trans below those temps..
an AT545 internally almost always runs warm esp if you climb any hills.. an MT643 behind an under-powered engine where it unlocks because you have it floored going 25 MPH up a grade will also get really hot..
most of the allison 1000/2000/3000 ive run into will lock in 2nd gear (all depends on the calibration program).. or will Lock the converter at a lower speed when they are hot.
I guess my takeaway with all this is keep your transmission comfortable!..
Old 08-07-2019, 01:50 PM   #118
With any new mechanical part that takes oil I like to fill it with the cheap stuff and go a hundred miles then change it again.
Old 08-07-2019, 01:52 PM   #119
AT545 only requires regular ATF fluid. They spec Transynd in FL due to the heat but 545's don't call for it. But FL bus regs state that all school buses in service MUST run Transynd. Maybe it makes their transmissions live longer since they deal with cheap under-maintained buses in a tropical climate here.
Everyone has a magical brand of oil that's better than anyone else's. Changing it regularly is the most important thing.
Old 08-13-2019, 07:51 PM   #120
Engine: DTA 360
Comfort Bus update and some sad news
First the sad news.
My father passed away last week Thursday afternoon. I have taken care of all the arrangements and am simply waiting on the judge to sign the death certificate. He will be interned at Fort Sam with his wife (my Mom) who passed 3 years prior. I'm trying to stay busy and not dwell on it, At least not until I have found a job. I will most likely have to give up the car. (2015 Nissan Altima SV) Its a recent acquisition back in Dec of 2018 and the purchase contract is for 5 years. Still have the bus. Trans swap was not done BUT still have all items previously listed to do the swap. Property owner/landlord has given me next month free so that is one expense I wont have to worry about.
Comfort Bus updates.
As previously mentioned I called the shop and had them stop all work. Got lucky and they were just barely tearing into it. Put it back into drive able condition, no charge. Using the bus as my daily driver after car is repo'd will not be fun BUT the car plus insurance is costing me $600 a month. Id rather keep it but realistically not possible. (shrugs) I can always shrink expenses more and save up to have it installed later.
Thanks to all of you in the Skoolie Forum especially Cadillackid, o1marc, EastCoastCB, alpine44, Native, Tango, Dirtdoctor, PNW_Steve, cowlitzcoach, geminusprime, Sleddgracer, Hazmat and Rivetboy. All of you made this a warm, family type experience . . . without the fights, mass alcohol abuse and police every weekend.
Not looking for sympathy, Simply dropping a line or two so you will understand when I dont respond or post as often as I used to.
