Old 01-11-2020, 05:58 PM   #21
mmoore6856's Avatar
Chassis: chevy
Engine: 3116 catapillar
I had not considered carriage bolts... did you Loctite the nuts Or anything? Gone down the road with them yet?[/QUOTE]
yes locktite used a drill driver to screw the nuts on as a 2 person job
mmoore6856 is offline   Reply With Quote
Old 08-12-2020, 11:21 AM   #22
Dizzyman's Avatar
Coachwork: Thomas MVP
Engine: Cat 3126B
Rated Cap: 20800
That is exactly what I did.. Two or three windows at a time using 18 gauge secured using SS closed end rivets and seam sealer.
I have been working inside of the bus during a pretty good storm. Rain in sheets pretty much raining sideways. Wind 30+mph and gusting to 50.
Not a drop of water in the bus except for what came in around the bottom of the service door. Ithere is a 3/16" gap at the base of the door that I need to address.
Resurrecting an old thread here - Did you experience any problems painting over the SS rivet heads? If not, how did you prep them and what kind of paint did you use?
Dizzyman is offline   Reply With Quote
