Old 11-14-2016, 10:59 PM   #21
Originally Posted by bullitt4514 View Post
The images resemble it. I need to pull the radiator out of the way so I can have a better look. It has a preheat button, not sure if it actually is working though.
Not sure which direction your engine is running... But L3E was stamped very prominently on side of block on mine
Old 11-14-2016, 11:14 PM   #22
It is transversely mounted so I will have to crawl under the bus to look
bullitt4514 is offline   Reply With Quote
Old 11-17-2016, 09:31 PM   #23
By searching on google, and by the "K8" marking I saw on the block, I believe it is a Kubota D850 possibly. I will find out more tomorrow
Old 11-18-2016, 08:21 PM   #24
It is a kubota the solenoid that shuts off the engine was not moving the shut off lever , as soon as I moved it it fired right up. Both compressors seem to be OK , but too cold to test I'd ac actually works.
Besides that , all the brake shoes and hardware look almost new , and in the rear it has 2 newer tires. I need to move the bus so I can find the date code.
Sent from my SM-N920C using Tapatalk
Old 11-18-2016, 09:16 PM   #25
Alan N's Avatar
Year: 1975
Chassis: Gillig
I would think about making that AC engine power a generator as well.
Or perhaps use it as is for charging your house batteries while parked.
I surely wouldn't take it out.
You got a good deal.
Have fun.
Alan N is offline   Reply With Quote
Old 11-18-2016, 09:21 PM   #26
Planning in getting. 10kw generator belt driven generator head to run off of it!
