Originally Posted by Hutchy
... if I could get a little better mileage and lower rpm at cruising speed as well as a little more ground clearance...
a)
How tall are your 19.5 tires?
How tall are your proposed 22.5 tires?
Example of ground-clearance gain:
On our ExpeditionVehicle, we went from standard street heavy-truck 22.5 to 50/50 on-/off-road high-profile logger-lug 24.5 wheels/tires for a difference of about three inches (about a fist).
To verify clearance:
We had the shop mount one 24.5 wheel/tire on a front axle end to check around suspension components and the fender...
... and...
...we were good.
How much does one 19.5 wheel/tire combination weigh?
How much does a 22.5 wheel/tire weigh?
My Opinion:
I think your brakes and suspension need to cope with the increased vertical and lateral gyroscopic forces.
I think your proposed swap moves the 'arm' significantly further from the hub, significantly increasing the leverage to those components.
Speaking of braking, your proposed increase in rotating mass is significant... and most of that mass is much further from the hub.
Fact, not opinion.
b)
I think your mpg will drop because you are turning greater resistance to change -- more weight further from the hub.
I think your top-end will suffer because your engine lacks the torque to spin that increased circumference.
The tire shop can compare the 'revolutions per mile' between your choices.
What could you gain?
A much better selection of sizes and tread patterns.
