Originally Posted by Earthspiritbus
The GMC and The Chevy is made by General Motors. They are basically the same. I would choose a five window bus and Diesel engine. I get more power with my diesel. When adding weight like you will with a conversion you need it
To clarify....
Gasoline engines make better hp than torque.
Diesel engines make better torque than hp.
Torque is what does your pulling. Horsepower is how fast it pulls. Since diesels make better torque, they feel like they have more power due to better low-end torque.
But a lot of people don't truly understand diesels. Some pointers for any diesel buyer... (especially a first-timer)
Most can't be pushed over 1800-2200 rpm without damage.
Maintenance is completely different. Fluids, intervals, everything.
Learn to check your fuel filters for water and install a water separator with a water drain if not already equipped.
