Originally Posted by Petenms
Just throwing this out there to see what you guys think. We have a few busses to choose from. First, a 93 Bluebird 11 window. Southern body in great shape inside and out. It has the 7.3 idi with the AT545 behind, not sure on the gearing. This is the first choice.
Next, a 1992 wayne, 10 window. It was a northern bus in its previous life, and is starting to show rust at the wheel wells, steps, ect. Now, the reason this one is on the table is it has a DTA360, with the AT545 behind it.
This probably seems a no brainer. We are planning on making a move to W. Texas, so its going to a dry climate.
I guess my real question is would the extra work with the Wayne be worth it to get the DTA360.
Were making a tiny home, which once we move, will likely only be moved a few times a year at the most.
So, a DTA360 with some body issues or BlueBird with an engine that had trouble moving an F250 unloaded.
Thanks guys and gals.
Me personally, If I was getting either one of those dirt cheap, $1,000 bucks or less, I would walk away and find something a liitle bit stronger.
The AT545 has been talked about enough, great/economical tranny for stop and go city pick and delivery type of operation but on the highways, no way!
7.3 idi, great motor in a pickup truck that pulls no load and doesn't want to go highway speeds up the hills but in a bus, you can expect it to run like a dog, a tired dog.
A dta360 slower than a 7.3.
Rust on the wheel wells...oh god.....
Mine had a small rust hole in the back passenger side corner of a RE Amtran.
Pulled the panel off to do the repair and found a major rust bed in that corner. Had to cut it all out, remediate and put it all back together.
Small rust hole above the front passenger wheel well, pilled that panel and ended up cutting out one crossmember and almost the entire floor above the two front wheel along with repairing both wheel wells.
If your not afraid of cutting and welding then not so hard of a job just time consuming. And if it comes out ugly no one is gonna care but you!
If your gonna spend all the time and money for just a one way trip to Texas and not take it out on the road but once or twice a year... it will run like a slow dog on the way to texas and anywhere else you go to!
Also, texas is damn hot! you might do better finding a bus with factory A/c for those days you do decide to go out and drive it !
For me, the two buses you described, I would walk away again unless I was getting them dirt cheap, free...
If your patient, shop around and get lucky you can find a decent bus with a bigger motor and better trans for not alot of money!
