-   -   RV Park AC Supply (https://www.skoolie.net/forums/f13/rv-park-ac-supply-10909.html)
03dunner 05-07-2015 01:14 PM
RV Park AC Supply
Hey Guys,
According to the spec sheet of the inverter/charger we're looking at, it only accepts 90130 VAC. From what I understand, a lot of RV parks seem to supply electricity only in the 220 VAC form. Can anyone suggest a way of down stepping this voltage before it hits our inverter/charger?
In case it is of use, here is the spec sheet:
https://www.xantrex.com/documents/Inv...1_Rev-C%29.pdf
Thanks everyone!
bansil 05-07-2015 01:29 PM
most campgrounds have 50amp, 30amp and 15amp 120V in the USA
where do you see 220?
the 50 amp is actually 2 legs of 120v for the added load of 2 circuits, it is still 120v (unless you do what I did and have a 220 option in the bus)
family wagon 05-07-2015 02:45 PM
I've never been able to determine whether there is any place in the US where the nominal is actually truly 220, or whether the nominal is really 240 everywhere here and the 220 number is just a relic of the past. In any case, in the US, consider the two to be 100% equivalent. It's like toe-MAY-toe vs toe-MAH-toe: either way, it's a juicy red thing thrown in cartoons at poor performers on stage.
Anyway, what bansil said is right. The 220/240 is "split phase" which means two 120 V supplies. The voltage from either hot to the neutral is 120, and between the hots is 240. If you only want 120 then just pick one of the hot legs and ignore the other one.
There's a picture of a typical 50A 240V campground pedestal there. (that site wouldn't let me deep link to their image directly) You could connect to just the ground, neutral, and one hot blade of the 50A receptacle or, more conveniently, use the TT-30 or 5-15 plugs instead. You'd have 120 either way. It isn't that most parks "only" have 240V, but rather they advertise that because it's a selling point -- they'll also have the traditional 120V sockets available too.
03dunner 05-12-2015 02:53 PM
Great. Thanks a bunch for the help!
