-   -   A New Member (https://www.skoolie.net/forums/f6/a-new-member-11890.html)
livelovelaugh91897 08-30-2015 01:28 PM
A New Member
Hello Everyone,
So my name is Ny(nickname) and due to my obsession with being free from rent and most bills and the obsession with travel I have decided to buy a bus and convert to a motor home. Yay how exciting!! anyways thanks for reading :)
nat_ster 08-30-2015 08:40 PM
Welcome.
Please be sure to read as many build threads as you can. That's where the real info and experience is.
Also look around the site, and read as much as you can before posting new threads. Everything you need is here if you look around.
After you narrow down your questions, we will be happy to help you out in detail.
Living off grid in a small space is a ton of work to get started. If you don't like working morning till night, being broke for the duration of the build, rejected by most, this may not be for you.
Nat
Tango 08-30-2015 09:13 PM
Howdy Ny & Welcome! --- You found the right place to do your homework. Just absorb as many threads as you can and you'll begin to develop a picture of what will fit your fantasy and budget and skill set.
livelovelaugh91897 08-31-2015 07:19 AM
Thanks Nat, for an informative reply luckily I kind of already live the life, so I'm not worry. And thank you again tango for replying.
