-   -   RV Windows help! (https://www.skoolie.net/forums/f13/rv-windows-help-13853.html)
slager55 05-13-2016 02:16 PM
RV Windows help!
I have taken all the bus windows out and put new skin over the old holes. Now I want to put 4 or 5 RV windows in. Has anyone does this that can give me advice? How do you cut the skin to put them in? What do you use to prevent any leaks. Do you cut from the inside first or the outside? Do you drill the corners first then cut? What do you cut with? How to you frame the windows to keep support in the bus? Any help is greatly appreciated? Thank you in advance.
superdave 05-14-2016 05:36 AM
yes pre drill holes and cut with snips if the metal is thin enough. a polyurethane caulk works the best. it takes mineral spirits to clean up.
slager55 05-16-2016 11:54 AM
RV Windows
Thank you for the tip. Do you have to create a frame in the inside of the bus for the window?
EastCoastCB 05-16-2016 02:09 PM
Yeah.
watch this guys videos and you'll see the general idea. He deals with this very topic.
CaptSquid 05-16-2016 03:56 PM
This is what I am installing:
Brass Porthole 12"
Stu & Filo. T 05-16-2016 07:17 PM
I installed 2 ea 60 in windows, I cut out a rib & put a header across tying them in to the other ribs also ran a frame at the bottom of the window tying to the other ribs I also used a sawzaw.
TAOLIK 06-29-2016 07:54 PM
Originally Posted by EastCoastCB (Post 148091)
Yeah.
Hey Eastcoast, did you intend to link to a video?
EastCoastCB 06-29-2016 10:03 PM
sorry-
https://www.youtube.com/watch?v=B2D6Bg9JxZY
Mudda Earth's channel
TAOLIK 06-29-2016 10:17 PM
Thanks CB, I'm not sure if that link was what I was expecting, but your video ended up inspiring me to google image search which sent me to this picture from wouldyoulookatthatbus
https://wouldyoulookatthatbus.files....pg?w=676&h=380
EastCoastCB 06-29-2016 10:46 PM
If you go to Mudda Earth's YT channel there is a vid of the rv window framing.
lebusmagique 03-09-2020 07:20 AM
Bumping a very old thread, but in the video where he puts in his windows, he just slathers on some 3M WindoWeld and pops it into place. Is that all that needs to be done?
