-   Cummins Drivetrain (https://www.skoolie.net/forums/f39/)
-   -   Everyone with a vp44 pump needs to read This (https://www.skoolie.net/forums/f39/everyone-with-a-vp44-pump-needs-to-read-this-20534.html)
Doe69936 12-24-2017 10:18 AM
https://www.bluechipdiesel.com/vp44_diagnostics.html?imz_s=upsps1gpha7omnqsokurob fom3
Rusty 12-24-2017 11:06 AM
Some good info there.
I have that injection pump on my 24V Cumins. The most important thing is that it gets good flow of fuel as it cools the pump. If the lift pump is weak, the VP44 will burn itself out.:eek:
I upgraded lift pumps (Raptor Air Dog) and put it by the tank to PUSH the fuel. Add a low fuel pressure alarm/light. Add a fuel pressure gauge.
Here is more good info
I replaced ALL my fuel lines with overkill 3000 psi hydraulic hose.
When I go to start it after sitting for weeks, I just bump the key and she's running- no more lost prime.:biggrin:
Rusty 12-24-2017 11:08 AM
Don't forget to check your harmonic balancer.:hide:
Doe69936 12-24-2017 01:43 PM
Huh? Harmonic balancer
Doe69936 12-24-2017 01:44 PM
That is a good site
