-   -   Roof raise.. self/paid?.. how did you go about it? (https://www.skoolie.net/forums/f13/roof-raise-self-paid-how-did-you-go-about-it-21264.html)
adic27 02-20-2018 03:19 PM
Was wondering if people can share there experience on what technique was used, tools/used and if they did it own there own or paid someone to do it. Pictures welcome!
Just looking to get motivated as I will attempt to do this by myself with no experience except what I've seen on youtube and this forum
Jdawgsfanasty 02-20-2018 04:21 PM
You might go solo...BUT there's a lot of weight in that roof...you need to know how plan the lift...be careful
Tango 02-20-2018 04:26 PM
Read the build threads. There a quite a few roof raises here showing lots of ways to go about it.
superdave 02-20-2018 05:11 PM
check ECCB's roll your own thread, we used the threaded rod technique to lift it 10 inches. easy with four people turning a wrench.
adic27 02-20-2018 05:20 PM
I've read a few. There is one guy who used a method that i wanna use but i can't remember his thread.
Twigg 02-20-2018 05:31 PM
That method is easy enough, if a little slower, with one person. It's the method I'd use because at no point is the roof detached from the bus. It's either help on by welds or bolts the entire time.
adic27 02-20-2018 05:59 PM
Yea ive been subscribed to that thread. Never checked his method tho.
Gdog 5651 02-20-2018 06:21 PM
I have done two raises that way and will be doing a third that way in March however the thought that the roof is attached the entire time is not true the nuts on the allthread are in between the two brackets and although it would take a hellacious lift the roof could be lifted or blown off I wouldn't try it on a stormy day you could avoid this by also putting nuts and washers on the top and bottom of the brackets but you would be doubling the amount of wrench time required to do the lift.
Twigg 02-20-2018 06:39 PM
Running nuts part-way up the lower threads and part-way down the upper threads would help avert disaster.
adic27 02-20-2018 07:00 PM
https://www.skoolie.net/forums/f11/th...gate-1564.html
This is the thread with the method i was talking about. Anyone else been following this thread?
adic27 03-02-2019 06:06 PM
So nobody else has used this method?? Thinking of giving it a go
Smokey's pipe dream 03-02-2019 07:45 PM
:popcorn:I'm in Maine but ill come to Texas and give you a hand if you'd like! we charge $2000 labor with your prep and your materials my son and i will show up and do it right up for you clean and professionally! you just need to strip it out and have the materials ill figure for you sitting there when we arrive! we can stop there or keep going and build you a complete bus? if you have a shop available to work in i can make all of your tanks brackets and any other hardware needed! we do fold out rooms and slideouts as well imagine a 23 x 13 living room in your bus we can do your in-floor heating system running off of an on-demand hot water heater or any other set up needed we are quick but we work pretty much straight through until the job is accomplished if the set up allows us too like noise restrictions stuff of that nature however we will not let the quality of our work slide no matter the circumstances! we try to have a 100% honest success rate with customers a happy customer is a good customer also for others reading this that may be interested we are building to order 28 to 31 a ford and 32 ford reproduction custom skoolie hot rods cowl forward reproduction parts cowl back completely custom close to original appearance with these, we offer a chopped top that lifts up to standing room height when you park! we will build other makes and years if the complete cowl forward is supplied to us in paintable condition! lilman772@gmail.com newenglandskoolies.com/forum:dance::thumb:
MarkyDee 03-02-2019 10:24 PM
I'm out of breath just reading that post....
EastCoastCB 03-03-2019 05:11 AM
A picture is worth a thousand words.
Drew Bru 03-03-2019 09:15 AM
Right? Many.....many thousands of words and not one picture to be seen.
o1marc 03-03-2019 12:19 PM
I think it's just wrong to jump into every build thread with an offer to commercially build it for you. I have no problem with it in the classifieds, maybe the site should charge a fee for sponsored vendors to even post a commercial offering.
Kinson 03-03-2019 12:31 PM
:hornet:Get outta here Marky! Run-on!(run along) PERIOD! /s /s
GWRider 03-03-2019 02:25 PM
Ditto, I have seen this offered in some other threads. I went to their site which is basically a forum that had a few posts. I only saw one bus that was nearly completed and was for sale at 30k. They should post in the classifieds.
o1marc 03-03-2019 02:27 PM
Someone does one roof raise and they are now a professional bus converter.:facepalm:
adic27 03-21-2019 01:06 PM
Wow! I didn't get notified of any of the replies after my last post. Just happened to check because I could remember if i even posted
