-   -   Attaching a Futon to flooring? (https://www.skoolie.net/forums/f13/attaching-a-futon-to-flooring-22766.html)
PowerDaniels 05-31-2018 07:14 PM
I recently acquired a nice futon for my bus that Id like to use. It has kind of plastic four sided/square like feet that can be screwed off the bottom. Does anyone have any suggestions of how to attach this couch to the floor? Or topics with how others have?
Thanks in advance
o1marc 05-31-2018 07:22 PM
If they screw off for leveling purposes I don't see why an oven or other appliance anti tip bracket won't work.
PNW_Steve 05-31-2018 07:23 PM
You definitely want it well secured!!
Post a pic of one of the feet. That may help us come up with ideas.
dan-fox 06-08-2018 03:59 PM
I've been mulling that one over myself. With a futon in a bus, you have a choice of either figuring out how to fasten it down in either of two places easily, or waste a lot of space behind the futon because of the way those things usually fold down. I'm up for any good ideas.
PowerDaniels 06-22-2019 07:58 PM
I haven't been around much lately, but I found a way to do it for the feet of the futon just recently. they're square peg legs about as thick as a fence post, so I bought two post base brackets for the front legs to sit in, screwed them to the floor and they fit perfectly. https://images.lowes.ca/img/p400/159...5002323_ca.jpg
Now I just need to build some sort of quick release mechanism to hold the futon to the floor since it sits in the base unattached. This way, I can lift it out of the base and lay it flat as a bed, when not in couch mode.
o1marc 06-22-2019 09:28 PM
I bought these for my ramp. An appropriate length would work for your app.
https://www.ebay.com/itm/FOUR-4-Avib...72.m2749.l2649
plfking 06-22-2019 11:19 PM
Bore a hole thru the bracket and the leg, and use a cotter pin to secure?
PowerDaniels 06-23-2019 07:25 PM
Both great suggestions. Thanks guys
