-   -   Random Spray Vs. Rigid Insulation Thoughts (https://www.skoolie.net/forums/f13/random-spray-vs-rigid-insulation-thoughts-23533.html)
o1marc 07-23-2018 07:41 PM
1 Attachment(s)
After much research I'm starting to lean away from spray foam. Spray kits run around $1/sf for 1" thick, or $1.50 for 1-1/2" thick. I was able to cut polyiso to tightly fit the curved spaces. It runs $10 for a 4' x 8' sheet or $.31/sf or $.94/sf.
The R factors are the same between the 2.
Some good info on why spray foam is not good inside "metal boxes":
https://www.insulation4less.com/Insu...ternative.aspx
brokedown 07-23-2018 08:27 PM
Rigid foam is much less expensive for sure! I'm using a little polyiso where I need something thin and flexible but mostly XPS because it's R value is stable over a range of temperatures.. Polyiso performance drops with cold temperatures.
