-   -   rust work and welding, Eastern MA (or Albany)? (https://www.skoolie.net/forums/f13/rust-work-and-welding-eastern-ma-or-albany-23965.html)
olives 08-23-2018 12:24 PM
Hi folks,
We need to remove and remediate rust from the underside and some spots inside the bus. We also need some associated welding - mostly patching rust holes and patching other holes that resulted in leaks and rust (e.g. where lights are and roof hatches).
We would like to hire someone to do this work, ideally in the next few weeks (depending how things go). It needs to be someone reliable and respectful of our bus, and willing to use the rust products we have found (we are chemically sensitive and some products won't work for us).
We're in Eastern MA (Boston Area) and hope to find someone(s) around here. If need be, we could probably go to Albany, NY, area since we have family there.
Advice? Leads? People we should call?
Thank you!
