-   Electrical, Charging and Solar (https://www.skoolie.net/forums/f49/)
-   -   DIY electrical fire (https://www.skoolie.net/forums/f49/diy-electrical-fire-24783.html)
turf 10-31-2018 11:23 PM
DIY electrical fire
I came to my bus yesterday to find no hot water.
today, i had a bit of time to investigate the problem and frankly i'm stoked that it wasn't worse.
i had installed a relay that i could switch the hot water heater on and off. i left the relay actuated for a number of days while plugged into 50 amp service.
it looks like it got hot and burnt a few wires. the fire was under my bed, and even left a soot stain on the bottom of my mattress. i never knew.
https://lh3.googleusercontent.com/oN...wOZhPS0s=w2400
cadillackid 11-01-2018 10:03 AM
yeoow!!! it may be a good thing it was all enclosed under the bed! moghtve snuffed itself out.. glad that wasnt worse..
most solenoids and relays will indicate continuous or momentary duty.. I remember using a ford starter relay as a fan relay for a hotrod i had.. yeah first 95 degree day I was out with that 500HP motor and the A/C blasting. lots of smoke (lucky no fire)..
somrthing like this might work?
https://www.amazon.com/CONTINUOUS-SO.../dp/B008R1T5IM
turf 11-01-2018 11:50 AM
Thanks Chris!
here is a link to the original. i dont see a rating for continuous, but i did not know to look.
https://www.ebay.com/itm/SSR-40DA-H-...cJFy:rk:2:pf:0
brokedown 11-01-2018 12:21 PM
I won't buy any more solenoids that aren't both rated for continuous duty and also have the trigger circuit isolated from the load circuit. I learned my lesson!
Something like this, which is what I have upgraded my glow plug solenoid to: https://www.supplyhouse.com/White-Ro...-Isolated-Coil
cadillackid 11-01-2018 12:44 PM
i didnt think about that... the self-feeding relay when they arc and short internally. unless isolated..
